Author Topic: AMD Display Driver Error  (Read 3201 times)
ReelTechnoFreek
  • Last login:August 18, 2018, 04:49:58 pm
« on: November 19, 2014, 06:40:12 pm »
Hey Calamity, another day another problem!
I think I'm close to giving up.
I hooked up my groovymame pc to my arcade crt tonight. Groovymame kept hanging or if I was on Windies desktop it flashed for a second.
This kept happening regularly , every 20 seconds at least
When on desktop I got a Windows error every time the screen flashed and I presume it I'd also the cause of groovymame hanging.
AMD display driver stopped responding and has recovered.
Any pointers on where to begin to resolving?
Calamity
  • Moderator
  • Last login:June 28, 2026, 10:13:15 am
  • Quote me with care
Re: AMD Display Driver Error
« Reply #1 on: November 20, 2014, 03:06:03 am »
Did that happen after using HS?
« Last Edit: November 20, 2014, 03:50:10 am by Calamity »
Steps to create a log:
ReelTechnoFreek
« Reply #2 on: November 20, 2014, 03:44:39 am »
Yes.
However I did a power off and on later and I was happening even on windows desktop.
This only happened late last night so my testing has been limited do far.
Calamity
  • Moderator
« Reply #3 on: November 20, 2014, 03:49:55 am »
Do you have the DXVA disabled as explained here? http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=379#p379
ReelTechnoFreek
« Reply #4 on: November 20, 2014, 06:24:17 am »
Yeah, I did that a while back but I'll double check that's it's disabled again.
When I rebooted the pc I only used groovymame through the command line not Hyperspin.
Same issue. Plus it was happening on the desktop before I launched anything.
I do have a suspicion on some dodgy ram so I'll try check that too. Don't know if related or not.
Calamity
  • Moderator
« Reply #5 on: November 20, 2014, 06:36:20 am »
I was afraid of that, just wanted to be sure.
IIRC you have an HD 4890. That's a monster card and it's causing other issues to some users. From now on I'm going to be advising against the HD 48xx cards.
It would be nice that everyone had a cheap and safe HD 4350 as a second card to plug it in in cases like this and be able to make sure it's not the video card.
ReelTechnoFreek
« Reply #6 on: November 20, 2014, 08:19:54 am »
Right, so you think it's the gfx card?
That's interesting as I've been testing the setup on my LCD monitor until yesterday and I never had that issue.
Only when I connected to the crt last night did the problem begin.
Calamity
  • Moderator
« Reply #7 on: November 20, 2014, 08:47:44 am »
So when we talked the other day about the -frame_delay option you were actually using an LCD?
Anyway, I'm not saying it's the card. Just wondering. Several users reported detection issues lately for their 48xx cards, probably unrelated but...
