Author Topic: Tone Arm Wiring for 1964 Tropicana Jukebox  (Read 2098 times)
FLBill
  • Last login:February 20, 2015, 04:20:11 pm
« on: October 27, 2014, 03:07:16 pm »
Hi
     New to this forum. I have a '64 Row AMI Tropicana JBM 200 Jukebox. I would like to know if someone could e-mail me a schematic or otherwise explain the wiring from the needle head down to where the wires are soldered on to the little 7 pin plug which the wiring from, down at the  Amp to  the tone arm plugs into.
ss454_@hotmail.com
Thank You
Bill
Generic Eric
Re: Tone Arm Wiring for 1964 Tropicana Jukebox
« Reply #1 on: October 27, 2014, 03:09:55 pm »
Do you have a manual?
http://www.ebay.com/itm/MANUALE-COMPLETO-manual-JUKEBOX-ROWE-AMI-M-TROPICANA-JBM-1964-/171259600294
In the description, it says its in english
FLBill
« Reply #2 on: October 27, 2014, 05:03:19 pm »
Hi
        Yes , I have a manual, in fact two,.... a service and a parts  manual. I know that there is a schematic in it, but it is very faded.  I think a more clear schematic might help understand what is going on.
         There is a seven pin (male) plug which comes from the amp and  plugs into the tone arm. Of the seven pins, I have determined one is not utilized,  leaving 6 pins.  Of the 6 pins, the following seems to be the case for their designations: (The way I have numbered them is not corresponding to the numbering of the actual plug).
1- R channel center pin of RCA plug down at Amp
2- L channel center pin of RCA plug down at Amp
3- R side shield for wiring
4- L side shield for wiring
5- R side RCA outter connection of RCA plug at Amp
6- L side RCA outter connection  of RCA plug at Amp
With the Ohm meter, other than the pins which correspond to the center pins of the RCA plug ,  the rest read out as common. I am checking the pins with both RCA plugs unplugged from the amp.  This would mean that the shields and the RCA outter plug are all common.
QUESTION:
Does it matter then which of the remaining 4 wires get soldered onto the tone arm side female plug remaining wire tabs, which all seem as common  ?
Hope I was clear on my description and related question.
Thank You
Bill
« Last Edit: October 28, 2014, 04:45:26 pm by FLBill »
FLBill
« Reply #3 on: November 09, 2014, 05:44:16 pm »
Hey
         Got it all figured out now . Thanks anyway. Physically traced the wires from the AMP up to the tone arm. with the trusty Ohm meter;   followed the cartridge picture pin layout regarding the  L,  R,  LG and RG pin to wire orientation in the manual. Had to re-solder at the base plug    It was an ordeal.  It was wrong. Sounds great now, and out of both sides.
Bill
