Author Topic: [SOLVED] Need some guidance with a batch file. Help a dummy?  (Read 2160 times)
Louis Tully
« on: October 24, 2014, 09:30:08 am »
« Last Edit: February 12, 2015, 05:51:10 pm by Louis Tully »
lilshawn
  • Last login:Today at 12:51:25 pm
Re: Need some guidance with a batch file. Help a dummy?
« Reply #1 on: October 24, 2014, 11:04:35 am »
when I exit Mame after using the batch to launch it, there's an open cmd prompt window.
if you append an "exit" command after you run the game...
IE:
Code: [Select]
@echo off
cls
cd C:\MameUIv.138
MameUI32.exe roms\astdelux2.zip -skip_gameinfo -full_screen_brightness 1.0 -contrast 2.0 -beam 1.2 -d3dversion 9 -filter -use_bezels -throttle -waitvsync -effect ApertureHRES_j4
exit
the batch file should resume once the program ends... that means the exit command will run (since it's the next command) and kill the window.
rockyrocket
« Reply #2 on: October 24, 2014, 12:42:55 pm »
This intrigued me so I just had a quick play.
Path`s` are going to be different but for asteroids delux from AAE this Bat works for me...
Code: [Select]
@echo off
D:
CD "D:\emulators\64bit\AAE"
aae astdelux
And to start the asteroids.bat and another Batllezone plus bat via AHK hotkeys - this works....
Code: [Select]
a::
Send {Esc Down}, Send {Esc Up} ;quits aae
Sleep, 1000
Run, C:\Users\Mame seven\Desktop\AsteroidsDelux.bat
return
b::
Sleep, 1000
Run, C:\Users\Mame seven\Desktop\BattleZonePlus.bat
return
Not the most elegant way but it works.
This page has some good info for running bats without cmd windows popping up but it may be best just to call the games directly via AHK?.
Anyway hope that helps a bit?.
Louis Tully
« Reply #3 on: October 24, 2014, 03:13:16 pm »
« Last Edit: February 12, 2015, 05:51:18 pm by Louis Tully »
jdbailey1206
Re: [SOLVED] Need some guidance with a batch file. Help a dummy?
« Reply #4 on: October 24, 2014, 03:19:09 pm »
Now youre not a .bat dummy anymore.  They are neat little files once you get the hang of them. :)
rockyrocket
« Reply #5 on: October 24, 2014, 04:27:54 pm »
Sweet, get building!.
Thinking some more on this if your 3 game launch buttons were for example A,B and Shift then button combo`s can be used to shut down or reboot as well.
Code: [Select]
+A::Shutdown, 2 ;Reboot
+B::Shutdown, 1 ;Shutdown
You really would have a bare metal system then.
« Last Edit: October 24, 2014, 04:44:31 pm by rockyrocket »
Louis Tully
« Reply #6 on: October 25, 2014, 03:56:25 am »
« Last Edit: February 12, 2015, 05:51:55 pm by Louis Tully »
rockyrocket
« Reply #7 on: October 25, 2014, 04:55:00 am »
No worries, glad to help.
Put a shortcut to one of your Bat`s into your start up folder and you should just boot straight into a game and never see the desktop.
Now get building  ;D .
Edit - Glad you have no command window pop up, on my test bed (Win7-64) I do get a visable window so had to use that VBS trick linked to above.
It is messy as AHK calls a VBS that stars a Bat, but no window is seen - the VBS looks like this....
Code: [Select]
Set WshShell = CreateObject("WScript.Shell")
WshShell.Run chr(34) & "C:\Users\Mame seven\Desktop\AAE Bat`s\AsteroidsDelux.bat" & Chr(34), 0
Set WshShell = Nothing
And now the AHK is this...
Code: [Select]
#NoEnv
SetWorkingDir %A_ScriptDir%
a::
Sleep, 1000
Run, %A_ScriptDir%\Astdelux.vbs
return
b::
Sleep, 1000
Run, %A_ScriptDir%\BattleZonePlus.vbs
return
« Last Edit: October 25, 2014, 05:35:08 am by rockyrocket »
Louis Tully
« Reply #8 on: October 25, 2014, 05:15:58 am »
« Last Edit: February 12, 2015, 05:52:10 pm by Louis Tully »
rockyrocket
« Reply #9 on: October 25, 2014, 05:19:30 am »
Looks good buddy!.
You ninja`ed a response in whilst I was editing my last post  ;D .
A funky select sound may be sweet too?
I use the attached photon sound in one of my cabs - just drop it or any other sound into the same dir as the AHK file and then use..
Code: [Select]
y::
SoundPlay, launch.mp3
Sleep, 1000
Run, C:\ADCabBatScripts\aaeAsteroids.bat
return
u::
Sleep, 1000
Run, C:\ADCabBatScripts\aaeAsteroidsDeluxe.bat
return
i::
Sleep, 1000
Run, C:\ADCabBatScripts\aaeArmorAttack.bat
return
You could even use a different sound for each game?.
« Last Edit: October 25, 2014, 07:08:58 am by rockyrocket »
