Author Topic: 8-Way Joy Switches - How Many?  (Read 1696 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« on: December 14, 2003, 08:28:24 am »
Does an 8-way joy have 8 switches, or does it work using AND logic?
IE: Up AND left = Diagonal
I'm trying to figure out which I-PAC to buy, so I'm counting my inputs :)
%$#@!&* machine took my quarter!
Tiger-Heli
    • Tiger-Heli
Re:8-Way Joy Switches - How Many?
« Reply #1 on: December 14, 2003, 09:00:43 am »
It only has 4 microswitches, so 4 inputs per encoder.
See http://www.fraggersxtreme.com/arcadepanels/encoder/index.htm for a comparison of encoders, along with info on number of inputs, for example, you only need 4 buttons for Players 3 and 4, for Arcade games.  (Console emu's are a different story.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: December 14, 2003, 09:27:56 am »
Just realized you're also the 3-joystick guy.
Remember you can wire the 4-way joy to the same inputs as the Left 8-way, saving you 4-inputs.  (At the expense that bumping the wrong stick will mess up your game.)
Oldskool
« Reply #3 on: December 14, 2003, 09:51:12 am »
Thanks for the reply Tiger.
Yes, I'm the three joy guy, but I'm now considering keeping it to two, to prevent CP clutter.
You can easily operate a joy that's slightly off center for single player games, without the need for a dedicated stick.
It looks like I'll be able to get by with the smaller I-PAC.
Cheers.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: December 14, 2003, 09:56:53 am »
>Yes, I'm the three joy guy, but I'm now considering >keeping it to two, to prevent CP clutter.
>You can easily operate a joy that's slightly off center >for single player games, without the need for a >dedicated stick.
Yeah, that's what I was getting at in my reply in your other thread.
There's also the KeyWiz from www.groovygamegear.com
>Cheers.
But Cheers is a pretty European sign-off, so maybe the reason for the Ultimarc leaning.
No worries
(and no, I'm not for Ozland).
