Author Topic: Rockola 437 vs. 440 Interchangability  (Read 3475 times)
3BadBirds
  • Last login:October 24, 2014, 04:37:56 pm
« on: October 22, 2014, 08:58:38 am »
Hi!
Several months ago I picked up a Rockola 437 Ultra.  I'm new to the hobby and thought restoring it would be a good way to lean more about how they work.  Shortly I started tearing in to it, however, I noticed this juke was in much worse shape mechanically then I had originally thought.
I recently noticed a local ad from someone selling parts from a Rockola 440 including a complete working mechanism.  I know the electronic components between these two models are slightly different but was wondering if the other physical pieces were a direct swap - they looked very similar.  If they are that would save me a lot of time and aggravation.
Any help would be appreciated!
Cheers!
York
Doghouse Riley
  • Last login:February 24, 2023, 05:16:10 am
Re: Rockola 437 vs. 440 Interchangability
« Reply #1 on: October 23, 2014, 04:15:55 pm »
I've no way of telling as I've never seen inside either one of them. I would think the mechanics are pretty much the same  with 160 selections. They even both have the same configuration of selector buttons. These were only a year apart as for date of manufacture. But someone may yet tell you, they are completely different which would surprise me.
 I've a 443 and a 468. Seven years apart. There's big cosmetic differences and in the selection button mechanics.  One's 160 the other 100.
But the mechanics look identical other than the different sized wobble plates.
« Last Edit: October 24, 2014, 05:07:19 pm by Doghouse Riley »
I don't mind if you don't like my manners.
I don't like them myself, they're pretty bad!
I grieve over them on long winter evenings.
3BadBirds
« Reply #2 on: October 24, 2014, 04:38:26 pm »
I picked up the 440 and will keep my fingers crossed.  I already have a manual for 437 Ultra so once I get one for the 440 I should be in good shape.  These machines are only a year apart and the cabinets are very similar in size and design - the biggest difference being that you could still see the record play on the 437.
More to come....
Thanks for the help!
Chris
    • Chris's MAME Cabinet
« Reply #3 on: December 22, 2014, 10:26:32 pm »
Any luck?
Chris
--Chris
