Author Topic: 25 cent button from groovygamer wiring question  (Read 1249 times)
pman77
  • Last login:September 19, 2019, 05:27:19 pm
    • Youtube channel
« on: October 21, 2014, 03:42:47 pm »
*** figured it out the solid black is ground and the green/black is 5v. both need to be plugged in.
I got the groovygamer 25 illuminated push buttons and looking at the instructions it talks about a red wire going to 5v on the molex and the black going to LED-WIZ which i don't have. http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=295 However my buttons came with a solid black wire and a green/black striped wire not a red one. I'm assuming the green/black goes to the the 5v on the molex and the solid black on the button isn't used ?
Also for testing purposes does the ground on the button have to be connected for it to illuminate?
thanks for the help.
P
« Last Edit: October 21, 2014, 10:05:37 pm by pman77 »
mvolke1
  • Last login:August 27, 2020, 09:48:24 am
    • My Pi-Powered Galaga-Thmed Bartop
Re: 25 cent button from groovygamer wiring question
« Reply #1 on: October 21, 2014, 04:13:11 pm »
I just did these. I can check when I get home later. I am using a 12v adapter, though. If I remember correctly, I cut the tip off the adapter cord and I linked the green with the striped wire on the adapter, and the solid black with the solid black and it worked.
I'm with stupid.
pman77
    • Youtube channel
« Reply #2 on: October 21, 2014, 09:27:41 pm »
« Last Edit: October 21, 2014, 10:06:12 pm by pman77 »
