Author Topic: (slightly off-topic) Using the Model1 Comm-Board with a PC :D  (Read 5330 times)
SailorSat
  • Last login:September 20, 2026, 09:10:13 pm
    • For Amusement Only e.V.
« on: October 19, 2014, 11:59:36 am »
Hi again :) This may get a little off-topic and even more techie at some parts.
This is a "spin off" thread from this thread.
The idea is to build an interface for the model1 comm board to do some "blackbox" testing.
For the sake of simplicity, I choose the IBM PC's ISA-bus, as it features a lot of control logic that we need.
The basic idea is to use a (rather) small I/O area to access the model1 comm boards "host" port.
Logic - Ideas
The model1 comm board features an 21 bit address bus (A0 to A20) and 16 bit data bus (D0 to D15), there are several other control signals, as IOW-, IOR-, VINT-, EX1- and EXWAIT-.
And of course there is a 32M pin for the 32MHz OSC on the model1 cpu board.
I came up with a rather simple "glue" logic.
(please note - this image is neither correct nor complete :))
Hardware
The model1 comm board features an 21 bit address bus (A0 to A20) and 16 bit data bus (D0 to D15).
These 21 address bits are grouped:
- A0 to A12
- A16 to A20
A1 to A11 are connected to the shared memory chips - nothing special about it.
A1, A12, (A0 or A16), (A17 or A18), A19, A20, EX1-, IOR- and IOW- are connected to IC6 - a PAL18 which serves as address decoder.
So the idea was to read out the PAL and check what it does... I don't get that JEDEC stuff, so I used a rather "hacky" approach - with breadboard and some wires :)
As it turns out - A16 to A19 need to be "low", A20 and EX1 need to be "high" - to select the comm board in any way.
The comm board is "mapped" in the model1 address space at 0xB00000 so we can guess which address bits would be used.
Code: [Select]
HEX     BIT
B00000  1011 0000 0000 0000 0000 0000
B01000  1011 0000 0001 0000 0000 0000
        2222 1111 1111 1100 0000 0000
        3210 9876 5432 1098 7654 3210
           + ----    x xxxx xxxx xxxx
That leads to this:
Code: [Select]
Read  @ B00000 = MEMR
Write @ B00000 = MEMW
Read  @ B00FFF = MEMR
Write @ B00FFF = MEMW
Read  @ B01000 = CNRD (Bit0)
Write @ B01000 = CNWR (Bit0)
Read  @ B01002 = FGRD (Bit0 & Bit7 [ZFGWR])
Write @ B01002 = FGWR (Bit0)
Bridgeboard - ISA side
The bridgeboard is rather simple.
For the 32MHz signal I used a 32MHz OSC... quite simple huh? ;)
I use a 74682 as "chip select" decoder for the ISA-bus.
P-Signal use A3 to A9 and AEN signals.
Q-Signal uses 7 Jumpers and GND.
If P equals Q we know our bridge is accessed - IOCS- goes "low".
I also use two 74138 as read- and write-address decoder.
ABC-Inputs are connected with A0 to A2.
G2A- is connected to CS-.
G2B- is connected to IOR- / IOW-.
I only use the Y0- and Y2- outputs - W0-/W2- and R0-/R2-.
As this is a 16 bit capable card, I need to pull down IOCS16-.
Also, if the comm boards memory is "busy", I need to pull down IOCHRDY.
For that, I use a 74125 and a 7432.
CS- is used to connect IOCS16- to GND.
(CS- or EXWAIT-) is used to connect IOCHRDY to GND.
This works because both signals CS- and EXWAIT- need are "active low", and the OR-gate output gets "low" only if both inputs are "low" too.
As for some other control signals.
The ISA-bus has a RESET signal, and the model1 comm board uses a RES- signal.
I simply invert the signal using an 7404.
To latch the address, I use two 74273.
W2- signal is used to "update" the latched address.
the outputs are connected to the comm boards address lines A0 to A15
As I don't have any VSYNC signal on the ISA bus I choose to use R2- as VINT- signal. More on this one later.
W0- is connected to the comm boards IOW- line.
R0- is connected to the comm boards IOR- line.
I planed to generate a valid EX1- signal like this:
W0- and R0- get inverted by the 7404, both signals are then fed to the 7432 - the ORed result is then inverted again (7404) and thus used as EX1-.
However, in the end I became lazy and simply connected EX1- to GND ;)
The data lines are connected to both the 74273 inputs as well as the comm boards data lines D0 to D15.
At first I used two 74645 bus gates - however I removed them later as they are not needed.
At last... nothing blew up after plugin it in for the first time :D
Bridgeboard - model1 comm board side
The "other" side of the bridge is a simple (still messy) wire adapter.
It simply plugs into the comm board :)
(Phew... nothing blew up :D)
Software side
As for the PC side, the bridgeboard is located at IO 0x300 to 0x307:
Writes to 0x302 update the address latches (16 bit).
Reads from 0x302 trigger a VINT-. (theoretical - should be about 58hz?)
Reads/Writes to 0x300 are processed by the comm board.
So if I want to read data located at 0x0123 from the comm boards shared memory...
I write 0x0123 to 0x302 and then read from 0x300.
One thing I didn't actually pay attention to, is the endianess. My Intel CPU (as well as the comm boards Z80) use little-endian. However I don't know what the NEC V60 used on the model1 cpu board does.
I did some simple tests routines (in Visual Basic ^^) to check the bridgeboard.
I can access both CN (0x1000) and FG (0x1002) "registers" without problems.
My SRAM test (reads and writes from/to 0x0000 to 0x0FFF) indicates that this is working too - however the memory at 0x0000 always returns 0xFF.. which I suppose gets writen there by the comm boards Z80.
*UPDATE*
Turned out the SRAM was accessed to fast, took that into account when writing, now everything works.
*UPDATE2*
VINT- didn't work as intended, the ISA IOR- signal is "too short" for the Z80 to recognize as interupt. Using the VGAs (negative) VSYNC for now.
*UPDATE3*
Linking up works :) Now I need to visit a friend and "hook" this thing into a real Virtua Racing network :D
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
vandale
  • Last login:September 11, 2024, 07:07:45 am
  • Id 10 and t error
Re: (slightly off-topic) Using the Model1 Comm-Board with a PC :D
« Reply #1 on: October 22, 2014, 06:14:43 am »
Holy moly  :o
Brian74
  • Yep... I built that!!
« Reply #2 on: October 22, 2014, 03:35:05 pm »
Umm, I would not be able to keep track of ALL those wires.. +1 for you  :applaud:
Nuexzz
  • Last login:October 01, 2023, 01:26:58 am
« Reply #3 on: October 23, 2014, 01:30:07 am »
I never had the opportunity to have an arcade board then I wonder WHAT THE HELL ARE YOU DOING ?? :laugh2: haha I understand that this plate creating a network of m1 and connecting it to a cpu (pc) and you would achieve with this?
sorry for my ignorance
SailorSat
« Reply #4 on: October 23, 2014, 11:08:27 am »
Step 1 - connecting a "real" virtua racing with an "emulted" virtua racing.
Step 2 - same with daytona usa
Step 3 - replacing the comm board with a selfmade one arduino/raspberry pi and ethernet? ^^ (on the real board)
Nuexzz
« Reply #5 on: October 29, 2014, 07:29:52 pm »
cool!! assuming your board is working well or better than a network card m1 / m2 etc you could dump it and create software as a "network emulator" for use in lan, p2p and online?
