Author Topic: Help Identify this chassis..  (Read 2480 times)
dextercf
  • [thisispersonal]
« on: October 11, 2014, 10:06:54 am »
Hi guys.
Regular old "Help identify" topic here.
Got this cabinet which I just powered on and played for a few minutes.
It had to warm up for the hight of the picture to "build up".. slowly stretching to its vertical hight.
After about an hour it collapsed.
After looking at the chassis, seems some caps sprung a leak.
Have ordered some 220uf50V caps, but seems I need more parts.
The chassis is also missing the POT for the horizontal hight regulator, looks like it is replaced with a couple resistors.
Anyone able to help out?
ed12
Re: Help Identify this chassis..
« Reply #1 on: October 11, 2014, 11:50:47 am »
look's like 1 of rickn ch288 to me
send rickn a pm
ed
grantspain
« Reply #2 on: October 12, 2014, 05:07:42 am »
I think its  a sanwa,possibly a 14VC21S from something like a mushiking
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #3 on: October 13, 2014, 03:34:37 pm »
Might be a Chenghong CH218 or CH 888. You msut use an Isolation transforme. Some one has changed one of the controls... right in front of the black control is an electrolytic electrolytic cap that needs to be replaced, slao that large black cap has a slight bulge. It is the input power filter cap, looks like it has a bulge.
I will check tomorrow if we have any of these boards, but odds are slim.
BTW what is the problem?
Good Luck!
Rick@Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
dextercf
  • [thisispersonal]
« Reply #4 on: October 19, 2014, 03:11:20 pm »
Thanks guys!
The image has collapsed.
It is hooked up via an isolation transformer.
I have ordered 220uf50V caps, but there are certainly more work needed on this board as I look further.
Any luck on getting a match?
grantspain
« Reply #5 on: October 19, 2014, 05:51:23 pm »
what does the screen printing say on the circuit board in front of the flyback,
it does look to be a sanwa -exactly the same as two i repaired a few weeks ago
dextercf
  • [thisispersonal]
« Reply #6 on: October 21, 2014, 06:02:00 pm »
I better be pulling it out of the cab then, hard to reach from where it is installed.
Be back with more later..
