Author Topic: Is there a standard distance betwen buttons in a CP ???  (Read 4691 times)
alank2
  • Last login:June 25, 2023, 10:05:48 pm
« on: December 12, 2003, 03:11:43 pm »
Hi everyone,
I'm planning on using 6 buttons in a 3 wide x 2 tall configuration.
At 1.5" between holes, this leaves about 3/16" space between buttons.
If I went to 1.75, this would then leave 7/16" space between buttons.
Is there a standard?
What was used on cabs that had this layout (like streetfighter?)
Thanks,
Alan
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
Re:Is there a standard distance betwen buttons in a CP ???
« Reply #1 on: December 12, 2003, 03:21:44 pm »
here is a link to Snakes webpage I hope he doesnt mind
http://www.freewebs.com/snaaake/M2.htm
on the bottom of that page he has a pic of his CP layout with schematics and spacing, if you like his CP layout you should try that
"Owens is the ringleader in the ass hat circus"  D K
TalkingOctopus
    • My Arcade
« Reply #2 on: December 12, 2003, 04:14:27 pm »
I have the standard capcom fighter layout posted on my website as well as the template I used for my cp.
http://webpages.charter.net/rbecker5/files.html
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: December 12, 2003, 04:33:17 pm »
See:
http://www.fraggersxtreme.com/arcadepanels/faq.htm#What is the minimum button spacing that I can use?
I plan to use 1.5 between the button centers and 3 inches between the joystick center and the center of the first button, which is what talking octopus has on his template.
Someone should sticky this also, gets asked a lot.
SNAAAKE
  • -Banned-
« Reply #4 on: December 13, 2003, 01:23:41 pm »
This one is so pefect.I highly recomended :)
Dartful Dodger
  • Newer isn't always better.
« Reply #5 on: December 15, 2003, 02:23:49 pm »
The metric system!  That's not perfect at all.
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #6 on: December 15, 2003, 02:32:03 pm »
metric rocks! i used to hate it but when i started getting into cars all i work on now is imports so i like mm instead of 5/16 and all that crap
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: December 15, 2003, 02:41:58 pm »
Quote from: Dartful Dodger link=board=1;threadid=
[quote
Actually, if you do the math, SNAAAKE's dimensions are less than a tenth of an inch different from mine and Octupus's (Octopi's ??).
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #8 on: December 15, 2003, 04:03:41 pm »
Does anyone have a good Neo template?  That's the one with the curved buttons, right?
I'm looking for a good template to blow up to test out on a CP.  Here is one image I tracked down from another thread, but it wasn't a final...
Original Thread:
« Last Edit: December 15, 2003, 05:01:28 pm by Wienerdog »
This opinion was created from 100% post consumed information.
BillyJack
  • Last login:August 17, 2025, 02:58:00 pm
  • Must...paint...cab...! Must...buy...marquee..!
« Reply #9 on: December 18, 2003, 09:44:17 am »
I sure wish i knew the values for A through D however.  It's a nice design, but doesn't have all the answers, does it?  Am I looking at that pic wrong?
BillyJack
Now I've had my head in an elephant, a hippo, and a giant sloth.
-Homer
