Author Topic: Discoloration corner on monitor  (Read 1283 times)
cmjb13
  • Last login:November 23, 2025, 06:41:44 pm
« on: September 11, 2014, 08:22:16 pm »
Hope someone can assist...
I have a 1991 WWF wrestlefest cabinet.
Original monitor WG25K7193
I swap boards often and I noticed the top left corner of the screen is discolored.
I played around with the left speaker and noticed that when I moved it, the colors changed
I removed the speaker completely and the discoloration is still there.
This cabinet does move from time to time (to swap pcbs)
I'm a newbie when it comes to monitors, but what I'm reading is that a degauss may be in order.
Any advice is appreciated.
Slippyblade
Re: Discoloration corner on monitor
« Reply #1 on: September 11, 2014, 08:38:09 pm »
That's a de-gaussing issue.  If the monitor has a de-gauss circuit, use it.  Otherwise you might need to pick up a tool for doing it.
