Author Topic: Candy Cab Monitor problem?  (Read 1417 times)
HairyDVD
  • Last login:April 11, 2015, 06:58:50 pm
« on: September 11, 2014, 04:58:47 pm »
A friend just called me and said he had a candy cabinet with 300+ jamma board in it.  When he moved house, he tried the cab which used to work and now it does not.  He says it clicks when he tries to turn it on and no sound or picture on the screen.
He has tried to plug the crt monitor into a pc and says he may have made it worse ( trying to display a resolution it is not made for .... )
I am going to pop over at the weekend to take a look at it...
Does anyone have any advice as to what to check for.  I was going to check in this order
1) Jamma edge connector seated correctly
2) PSU working correctly at correct voltages DC
3) Video and audio out on Jamma correctly soldered
4) Monitor ?
Now... how would I check the monitor ?  How could I check it still works independently ?
ANy help appreciated guys as he wants to breathe new life into it.
Old Arcade intro videos on Youtube channel : http://www.youtube.com/user/HAIRYDVD
grantspain
Re: Candy Cab Monitor problem?
« Reply #1 on: September 11, 2014, 06:45:39 pm »
depending on the monitor he may have shorted the HOT by feeding it higher than 24khz
you should start by turning on machine and listen for monitor HT,you can turn the screen volts up on the flyback transformer to see if you get a raster
if you get a raster then using a multi meter check the power supply voltage to the edge connector
what cab is this?
sounds likely to be a blast city
HairyDVD
« Reply #2 on: September 12, 2014, 03:13:21 pm »
Only info i have till i visit is that its a candy with 29" monitor and 300 games on jamma board.
Will see him at weekend may ask for more advice, thanks
