Author Topic: PC audio to mono arcade speaker  (Read 2707 times)
bikeguychicago
  • Last login:March 19, 2018, 08:32:20 pm
« on: September 08, 2014, 11:23:30 pm »
I acquired a parted-out cabinet a while back that I've been slowly converting into a MAME cab. From the impression left on the cabinet it looked like it had only a single 6" speaker under the marquee.
Rather than modify the cabinet to include 2:1 audio, I would rather replicate the original mono sound output. Therefore, I am looking for suggestions on how I would go about setting up a system that would convert the stereo output from the PC to mono for the arcade speaker. I know that I will need an amplifier between the source and the speaker but other than that, I'm not sure what cables,converters,etc. I would need to achieve the desired output.
If anyone's done a similar setup with their cabinet and can offer any suggestions, I would appreciate if you could share your ideas on the matter.
mschwartz01
  • Last login:October 03, 2015, 07:15:48 pm
Re: PC audio to mono arcade speaker
« Reply #1 on: September 12, 2014, 08:30:33 am »
Take 1 of a set of PC speakers, remove the amp board from the case / speaker... run the speaker wire from the amp board to the speaker / jpac etc...
Very simple
Dermbrian
  • Last login:January 19, 2024, 05:05:16 pm
« Reply #2 on: September 12, 2014, 04:43:29 pm »
Simplest way.  I used this when I converted my 1929 radio cabinet to a glorified bluetooth speaker system/jukebox.
http://www.amazon.com/NXG-Technology-NX-C6-2-DVC-X-80-Watt--Ceiling/dp/B0067NZPDG/ref=sr_1_8?s=electronics&ie=UTF8&qid=1410554515&sr=1-8&keywords=Dual+Voice+Coil+In-Ceiling
Brian
