Author Topic: Rowe AMI CD100-A no sound when CD engages, speakers popping randomly  (Read 2911 times)
jklunk
  • Last login:September 13, 2014, 08:53:15 pm
Have a CD100-A that we brought back from the dead and it sounded great. However, this morning the CDs played perfectly, and all of a sudden sound stopped. The speakers will randomly pop, and the CD engages and appears to be playing, but no music transmits through the speakers. I disconnected the mute (orange/black) wire on the CCC just above P13, no dice.
I'm at a loss as to what to check next. Could the crossover board be bad? Any help is greatly appreciated.
Thanks,
Jarrod
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe AMI CD100-A no sound when CD engages, speakers popping randomly
« Reply #1 on: September 10, 2014, 05:45:35 am »
Hello Jarrod,
You have taken out the mute plug, I would therefore check the amplifier by plugging in a hi-fi separate such as a CD player or tape drive into the phono input. Ifyou get sound ok then the fault will be on the laser or the mechanism control/decoder.
Regards
Alan
Alan Hood
ami-man
UK
jklunk
« Reply #2 on: September 13, 2014, 08:51:41 pm »
Hi Alan,
I tried this and we do get sound so the issue is either in the laser or the mechanism/decoder.
Any suggestions as to where to look first?
Thanks,
Jarrod
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
« Reply #3 on: September 16, 2014, 09:26:54 pm »
The first thing I would do is go over all the connections. Pull all the plugs and re-seat them including the audio cables. Sometimes you get lucky and that will work.
ed12
« Reply #4 on: September 16, 2014, 09:49:55 pm »
hi
if u are in canada contact via pm
ed
