Author Topic: Raging Dragon work with AnalogMame??  (Read 5007 times)
Dr. Jay
  • Last login:January 05, 2003, 11:17:19 am
« on: March 10, 2002, 09:03:25 pm »
Howard (or anyone else who might know):
 I'm wanting to use AnalogMame so I can have multiple mouse support through Raging Dragon.  When I run AnalogMame by itself I have no problem with this, but when I edit the dragon.ini to use AnalogMame, the game loads fine, but the mice are completely unresponsive.  (Both mice)  Any ideas??
FYI, it does the same thing through EmuWizard, and I know I set up that part of the .ini correctly, because I erased the other mame.exe's and AnalogMame is the only one left in that directory.
Why multiple mice?  See my reply under your "killer instinct in Mame?" post...        Dr. J
  • Last login:Yesterday at 01:05:17 pm
Re: Raging Dragon work with AnalogMame??
« Reply #1 on: March 10, 2002, 10:00:16 pm »
is analoge mame dos or win based and does it have a mame32 gui or is it command prompt based?  I'm not too familair with it, but if you tell me this much then hopefully i can figure it out.
Brian
« Reply #2 on: March 10, 2002, 10:31:19 pm »
I am interested in this too. But, can analogmame run by itself, if your using the Win binary one? I have been playing with this a bit..couldnt you just change the name of analogmame to mame for the .exe? I am kinda new, so forgive me if i sound like i am clueless.
Brian
Dr. Jay
« Reply #3 on: March 10, 2002, 10:43:16 pm »
Hey,
 It's weird, because the download page has two versions, both of which bring up a mame32 gui.  Raging dragon doesn't give me any trouble when I use regular Mame32 though.  Hopefully you'll be able to learn more about it here: http://www.urebelscum.speedhost.com/
Thanks, -Dr. J
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: March 10, 2002, 10:57:00 pm »
What do you mean mame32 gui?
it's the normal win32 binary recompiled with directx 8 and taking advantage of dx8's control inteface essentially.
« Reply #5 on: March 10, 2002, 11:04:39 pm »
see that's what i thought.... you can run mame32 in rd but it's not reccomended...  It's best to stick to a regualr old win compile of mame, any version of  a wincompile will work with rd but mame32 variants are, well they're wierd.
Dr. Jay
« Reply #6 on: March 10, 2002, 11:06:45 pm »
Sometime in the near future, might you give it a shot to get multiple mice in, or are we out of luck??
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: March 11, 2002, 02:01:45 am »
Mame:Analog+ has two versions that do multiple mice: a Mame windows and a Mame32.  If you are downloading the mame32 version on both links, that's my fault;  I'll check and make sure the linked files are correct.  --EDIT--   The MAMEv58 links on the download page are correct: one is to the mame32:Analog+ version, the other is to the windows version.
I haven't tried Howard's Dragon FE, but the windows version of mame:Analog+ should work with it.  Except that Analog+'s multiple mouse options are set with added options in the mame.ini file.  I don't know how RD would handle this.  Maybe I'll check out Raging Dragon and see.:)
Robin
Knowledge is Power
Dr. Jay
« Reply #8 on: March 11, 2002, 10:18:02 am »
Thanks for checking it out.  I tried the links again, and I've got the windows version now.  I must have been acting silly and downloaded the same link twice  :P
 Anyway, the same problem is still there.  The game will load, but there no mouse support at all.  The in-mame gui doesn't even show the mouseaxes option.
 Also, It does make Raging Dragon act a little weird after exiting the game.  ARG!  I like multiple mice...
Brian
« Reply #9 on: March 11, 2002, 12:29:47 pm »
I hope to learn about this too... I really like RD, as well as ArcadeFX...but I want mutliple mice controls. How can you play warlords with joysticks? Ick!
Brian
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #10 on: March 11, 2002, 04:06:59 pm »
....Anyway, the same problem is still there.  The game will load, but there no mouse support at all.  The in-mame gui doesn't even show the mouseaxes option.
I'll look at it tonight.  Not that I need an excuse to play mame...;D
Robin
Knowledge is Power
twitami
  • Last login:December 22, 2016, 01:09:08 pm
« Reply #11 on: March 15, 2002, 08:13:10 am »
I am awaiting to find out if this works as well. Also wondering if anyone knows if it will work with Emulaxian or ArcadeFX. Gotta have two trackballs for Rampart!
Brian
