Author Topic: Happ competition joystick base slightly larger than my Ultimate base...  (Read 1354 times)
tylerwerrin
  • Last login:May 13, 2022, 02:16:31 pm
Hi guys,
I ordered some new Happ Competition joysticks to replace my Ultimate joysticks (to go along with my LED ball tops) and much to my dismay when they arrived I discovered that the base of the Competition sticks are ever so slightly larger than my Ultimate bases.
I had my CP milled professionally to a very exacting fit for the Ultimate joysticks so I don't really want to attempt to re-router out more wood. So that leaves just sanding down the sides of the bases until i can get them to fit. Does anyone have a recommended method for this? I've been using my files, but its taking forever because the plastic is relatively beefy.
Any tips for me?
adder
Re: Happ competition joystick base slightly larger than my Ultimate base...
« Reply #1 on: August 19, 2014, 05:53:29 pm »
maybe a hacksaw, or something hot like a soldering iron (of course do that outdoors eg. in garden and watch out for fumes, and your soldering iron will be a mess after ::))
adder
« Reply #2 on: August 19, 2014, 05:56:16 pm »
or sand the base by rubbing it firmly on rough concrete ground, you will find it will wear down quickly
tylerwerrin
« Reply #3 on: August 19, 2014, 05:59:42 pm »
its not really enough "meat" to hacksaw the plastic -- it's about 1/8 of an inch of plastic on all sides. Rubbing on concrete will probably work - has anyone tried it with a belt sander? Or something like that? I don't think the soldering iron thing will work, and if it does it will likely mangle the base and mess up the iron...
lamprey
« Reply #4 on: August 19, 2014, 06:31:28 pm »
A belt sander sounds like it would work. You can use a hand-held or a table-top. I picked up a "cheap" table top for anther project on sale at Harbor Freight and it works well enough for what it is:
http://www.harborfreight.com/4-inch-x-36-inch-belt-6-inch-disc-sander-97181.html
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #5 on: August 22, 2014, 10:01:07 pm »
Belt sander.
