Author Topic: groovymame linux vs windows?  (Read 4424 times)
Abducido
  • Last login:August 03, 2020, 06:57:27 pm
« on: August 11, 2014, 06:06:46 pm »
Excuse my English I'm using a translator, currently groovyarcade use distro and have excellent results, but as I want to make a collection of Mortal Kombat version I most want to play is the Dreamcast MKG, the same results are obtained in windows as Linux? that seem expectaculares. install windows just to add more consoles to groovyarcade Ideally you could install lxdream too.
Calamity
  • Moderator
  • Last login:Yesterday at 03:21:10 am
  • Quote me with care
Re: groovymame linux vs windows?
« Reply #1 on: August 13, 2014, 05:35:04 pm »
Hi Abducido,
If you really need to use Windows emulators then use Windows. GroovyMAME for Windows works just as good as in Linux if not better, but you need to make sure to use a compatible video card. Then you may find that the card that is compatible with GroovyMAME can't support certain new emulator that requires DirectX 11 or whatever. You need to make a choice.
Steps to create a log:
Abducido
« Reply #2 on: August 18, 2014, 11:13:58 am »
Thank you.
I have a ati radeon 4850 and core 2 duo 2 gigs in ram, what I love is the emulation dreamcast hopefully a new project groovyarcade be included, have controls parallel port so I can not have both systems because the wiring is good for windows linux, windows'm currently testing with hyper groovy and magical table, if not my idea but I notice a small inputlag compared to linux version, apparently in view seems to be the same.
gracias.
tengo una ati radeon hd4850 y core 2 duo 2 gigas en ram, lo que mas quiero es la emulacion de dreamcast ojala en un nuevo proyecto de groovyarcade se incluya, tengo los controles por puerto paralelo por lo que no puedo tener ambos sistemas ya que el cableado para linux no sirve para windows, actualmente estoy probando windows con groovy hyper y tabla magica, no se si es idea mia pero noto un pequeño inputlag comparado con la version de linux, aparentemente a la vista parece verse igual.
tengo un monitor generico arcade de 28,5 la idea es hacer que se vea tal cual la placa pcb de mk1 mk2 umk3 compre casi todo original solo no tengo la placa.
« Last Edit: August 18, 2014, 04:47:45 pm by Abducido »
