Author Topic: How to power monitor with 60 in 1  (Read 1463 times)
sollyscomputers
  • Last login:March 06, 2019, 01:31:51 am
  • Jukebox? check! Now on to cocktail cab
    • Softweb Developments
« on: August 07, 2014, 04:33:04 pm »
Hi people,
Am about to do the wiring in my cocktail cab 60 in 1 JAMMA with the standard power supply that comes with the complete kit.  My question, do I connect the monitor from the AC connectors of the power supply?  Or is there another way that I should be doing it?  I think it's OK this way but thought I'd check
Cheers
John
grantspain
Re: How to power monitor with 60 in 1
« Reply #1 on: August 07, 2014, 05:00:29 pm »
depends on the monitor model number,most run direct from mains but some require isolation transformers
sollyscomputers
« Reply #2 on: August 07, 2014, 06:31:01 pm »
Just a Dell 19" LCD
Slippyblade
« Reply #3 on: August 07, 2014, 06:45:29 pm »
Just drop a power strip inside the cabinet.  Plug the LCD into it and then plug the PS for the 60-in-1 into as well.
sollyscomputers
« Reply #4 on: August 07, 2014, 06:58:16 pm »
Yeah, keep it simple
