March 22, 2026, 10:29:31 pm
Very nice!
Looks like the edges of the screen are clipped, does the frame overlap the screen slightly?
Quote from: Barry Barcrest on August 11, 2014, 02:03:02 pmLooks like the edges of the screen are clipped, does the frame overlap the screen slightly?no ! thats how the software shows ! any way to adjust this ?
Quote from: mebronx2000 on August 11, 2014, 02:55:33 pmQuote from: Barry Barcrest on August 11, 2014, 02:03:02 pmLooks like the edges of the screen are clipped, does the frame overlap the screen slightly?no ! thats how the software shows ! any way to adjust this ? Without loading up E-Touch check the screen resolution and then see if it matches that of the skin. If not set the windows resolution to that of the skin and see if windows itself is also clipped. If it is your graphics card may offer some options to center the image and once windows displays fine e-touch will as well.
I know I'm dredging up a dead post, but hopefully the OP is still active.What size screen are you using?
