Author Topic: Dolphin Emulators  (Read 3354 times)
BzZziLLa
  • Last login:October 14, 2015, 10:58:28 pm
  • Seems legit!
Dolphin Emulators
« on: August 05, 2014, 11:00:07 pm »
I'm trying to run two versions of Dolphin emulator (gamecube/wii and triforce) in my cab. However, I'm running into an issue where both versions keep trying to save configs into the same folder in my "Documents" folder and it's causing them not to work right. Does anybody have a clue how to fix this?!?
Seems Legit!
ant2
  • Last login:June 02, 2024, 07:05:47 am
Re: Dolphin Emulators
« Reply #1 on: August 06, 2014, 03:10:58 am »
I have several versions of dolphin running, there is definitely a way of specifying directories within the config menu somewhere
SegaOutrun
  • Last login:March 28, 2019, 03:02:05 am
  • Brakes are overrated
« Reply #2 on: August 06, 2014, 05:11:31 am »
in the setting, you should be able to specify the paths. ive got multiple versions running just fine
BzZziLLa
  • Seems legit!
« Reply #3 on: August 06, 2014, 10:33:30 am »
Yea, i tried setting the paths and everything worked... until i rebooted my pc. However, i think i fixed the problem by simply deleting the folder in the documents section. Now the different versions seem to be playing nice again.
Seems Legit!
  • Last login:Today at 03:54:11 am
« Reply #4 on: August 06, 2014, 12:12:54 pm »
Just for the record, if you right-click on an individual game in your list and alter the settings that way, you'll get an individual config.  So aside from path settings, the easiest way is to right-click Mario Kart GP.... as it's the only triforce game.
