Author Topic: Need help with Led-wiz please  (Read 1335 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: August 03, 2014, 06:58:18 am »
I'm in the process of building a vpin, at the moment I'm setting up the feedback devices using a virtual output kit from zebsboards. I'm having a software issue regarding the leds, they flash once but will not stay lit. Using ledblinky simple led test if I lower the intensity right down I can get them to flicker as you can see from this video. I had them working one minute and then on the next boot I had this problem. If I unplug the ledwiz from the computer and touch a grounded wire to the ledwiz terminals my leds light up full brightness as they should. Any ideas ?
« Last Edit: August 03, 2014, 07:32:15 am by Connorsdad »
Connorsdad
Re: Need help with Led-wiz please
« Reply #1 on: August 03, 2014, 12:39:24 pm »
Fixed by running a wire from the gnd on the wiz to the gnd on the flasher board :)
