Author Topic: Upgrading Mame  (Read 1518 times)
tx2000
  • Last login:September 18, 2020, 04:23:09 pm
Upgrading Mame
« on: July 20, 2014, 07:24:44 am »
Currently I am using Mame 149 and I have tired to upgrade to 153 a couple of times . I used RomCenter to check/Fix the roms for the upgrade but I end up almost always damaging half of them.
What is the safest route to do it. Because I cannot get the save state on exit on mame 149 and in 153 I can, because I want when my daughter exit the game she can continue playing in the same spot without using f7 and shift f7.  thanks in advanced.
  • Last login:June 29, 2026, 11:23:56 pm
Re: Upgrading Mame
« Reply #1 on: July 20, 2014, 12:21:56 pm »
Well first off there is something you should know.  Mame's xml output has been "broken" for some time, so both romcenter and clrmamepro are going to show a dozen or more games that are incomplete when in fact they just don't have a full dump of the games yet.
To upgrade mame in the safest possible way....
(Note:  Do all this within the romcenter interface)
1.  DO NOT put your new roms in the same folder as your old ones.  Make a new folder, and add that folder to romcenter.
2.  After romcenter so it's scanning thing (the next day as slow as it is ;) ) right click on your new folder and select "fix"
3.  After that's done click the little icon's that filter the view until only the green roms are visible in that folder.
4.  Now right click inside the folder to select all and then go to shell operations and copy to copy all of these files into your main roms folder.
5.  Scan your main folder again, repeat steps 1-4 as needed.
tx2000
Re: Upgrading Mame
« Reply #2 on: July 20, 2014, 12:27:56 pm »
Thanks.  I will do that right now because it will take a couple of days  ;D
