Author Topic: SpinTrak Spinner pinout?  (Read 2421 times)
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« on: July 19, 2014, 06:38:53 am »
Hi
I have a USB SpinTrak spinner and would like to tap 5v from the unused pins on the tiny PCB to power a 5V button LED. Is this possible or a bad idea? I'm not using any mouse button inputs, so all the pins in this pic are 'free':
I read 5V across COM and all other pins. Does anyone know what the top two, unlabeled pins are, and/or can tell me which 2 pins I can safely connect to for the button LED, without registering a mouse button press?
Thanks in advance.
« Last Edit: July 19, 2014, 06:42:27 am by big10p »
kiwasabi
  • Last login:September 28, 2014, 12:14:51 pm
Re: SpinTrak Spinner pinout?
« Reply #1 on: July 21, 2014, 10:12:42 am »
OK so there are 9 pins correct? Looking straight at it with the board facing upwards, with the 5 pins on bottom, 4 pins on top, and the missing pin on the upper left... The 2 pins on the right (top and bottom pins) are 5V.
The wiring pinout is:
Brown  5V
White GND
Yellow X1
Green X2
So with that info in mind...you should be able to connect safely to the pin above/below where the reddish/brownish wire is connected. The mouse buttons should be the two pins above/below where the yellow and green wires are connected.
big10p
« Reply #2 on: July 25, 2014, 05:47:26 am »
Thanks for the reply. I emailed Andy at Ultimarc and he's says the only 5v pin is the one with the brown wire, and that it should be OK to power a LED from that. Seems a bit strange though as I read 5v across other pins too, but it's probably best to be on the safe side and just tap into the brown one.
  • Last login:Today at 02:57:42 am
« Reply #3 on: July 25, 2014, 05:08:52 pm »
You will read 5v on any encoder input, assuming it is an active-low device like the IPac, KeyWiz, KADE, etc.
Those inputs aren't designed to provide the current required to properly drive an LED.
A quick test on a KADE with a 12v LED revealed:
  * Connecting the LED between 5v and ground caused the LED to light brightly  :)
  * Connecting the LED between an input and ground triggered the associated output and caused the LED to light very dimly (~10% as bright?)
big10p
« Reply #4 on: July 25, 2014, 05:47:11 pm »
I see. The brown 5v wire it is, then. Thanks, Scott.  ;)
