Author Topic: 500 in 1 blue elf jamma pcb in a neo geo mvs cab....need alittle help  (Read 2673 times)
800screws
  • Last login:November 10, 2019, 07:37:29 am
im somewhat new to the arcade world, but after doing some research, I decided to thrown a 500 in 1 blue elf pcb in the cab, to play some of the side scrollers....
I have the neo geo cab, blue elf pcb, the paradise arcade elf ground correcting board, and the jammaboard.com neo to jamma converter...........what order do I plug this stuff in to make it work? if I can with these componets....I can get the elf to load, but the controls do not work so instead of cutting up my harness ( since I want to swap from the neo geo mvs and the elf) I bought the paradise grounding correcting board....I ran it elf to neo to jamma then the paradise board, and I still have no controls except for the 1st player "C" button.......
any ideas? thanks
800screws
well....kinda figured it out... I need to insert a coin and then it works, but then how do u get to the menu to set it up for free browse and free play?
are there any dip switches on the board?
800screws
2....not sure what they do! lol
You could always flip a dip see if it puts you to test menu, and if no switch it back. If you dont want to experiment on it, do you have a test or service button hooked up to your JAMMA rig?
800screws
I figured it out! I thought the S1 button was the start button, but its a button on the board....thanks
