Author Topic: Problem with the displayed image  (Read 2866 times)
adder
« on: July 07, 2014, 05:51:08 pm »
Hi, so i thought i would finally give groovymame a try for the first time after trying to understand it all for ages :)
im using windows xp 64bit, i have a X300 pcie card and installed crt_emudriver 9.3 (which detected my card as 'ATI Radeon X300/X550/X1050 Series')
i am using a scart tv which works fine when using a 16.4Khz scan rate
by the way my goals are (incase anyone thinks perhaps i should have set up in a different/better way to suit my needs), i will be physically rotating my tv to display between horizontal/vertical games. im not bothered about the refresh rate of the games i play being out by a few hz (eg. 3 hz in either direction). like most others i want to keep input lag down, and dont want any uneven stretching going on on the vertical for non-interlace games (but dont care what happens on the horizontal as long as it's not too 'visible' ;) - eg. i dont mind if it is a little bit blurry on the horizontal for some games.
in vmmaker.ini i used the following:
Code: [Select]
ListFromXML = 1
MonitorHorizontal = 0
MonitorType = "CUSTOM"
monitor_specs0    15625-16400, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 288, 448
ModeTableMethod_Custom = 0
ModeTableMethod_XML = 2
UpdateRegistry = 1
then i ran vmmaker.exe, there was several explosions and some fire (joke ;)) and now i have the following modelines in my registry (note: beforehand i edited ReslList.txt and removed everything but the '## Desktop ## 640 x 480 @ 30.000000 desktop' entry)
Code: [Select]
Modeline "640x480_60 15.6KHz 60.0Hz" 13.000 640 664 728 832 480 482 487 521 interlace -hsync -vsync
Modeline "1234x240_60 15.7KHz 60.0Hz" 25.060 1232 1280 1400 1600 240 242 245 261  -hsync -vsync
Modeline "1234x256_59 16.4KHz 59.2Hz" 26.760 1232 1288 1416 1632 256 258 261 277  -hsync -vsync
Modeline "1234x272_56 16.4KHz 56.0Hz" 26.760 1232 1288 1416 1632 272 274 277 293  -hsync -vsync
Modeline "1234x288_53 16.4KHz 53.1Hz" 26.760 1232 1288 1416 1632 288 290 293 309  -hsync -vsync
Modeline "1234x448_60 15.6KHz 60.0Hz" 25.010 1232 1280 1400 1600 448 466 471 521 interlace -hsync -vsync
Modeline "1234x464_60 15.6KHz 60.0Hz" 25.010 1232 1280 1400 1600 464 474 479 521 interlace -hsync -vsync
Modeline "1234x480_60 15.6KHz 60.0Hz" 25.010 1232 1280 1400 1600 480 482 487 521 interlace -hsync -vsync
Modeline "1234x496_60 16.2KHz 60.0Hz" 26.130 1232 1288 1408 1616 496 499 504 539 interlace -hsync -vsync
Modeline "1234x512_59 16.4KHz 59.0Hz" 26.740 1232 1288 1416 1632 512 515 520 555 interlace -hsync -vsync
Modeline "1234x528_57 16.4KHz 57.4Hz" 26.740 1232 1288 1416 1632 528 531 536 571 interlace -hsync -vsync
Modeline "1234x544_56 16.4KHz 55.8Hz" 26.740 1232 1288 1416 1632 544 547 552 587 interlace -hsync -vsync
Modeline "1234x560_54 16.4KHz 54.3Hz" 26.730 1232 1288 1416 1632 560 563 568 603 interlace -hsync -vsync
Modeline "1234x576_53 16.4KHz 52.9Hz" 26.730 1232 1288 1416 1632 576 579 584 619 interlace -hsync -vsync
ok and then in the mame.ini which i generated with the -cc command, i made some changes (eg. 'monitor arcade_15'), my mame.ini can be seen at the bottom of this post.
then, when i tried some various games, i have the problem which i think some others here had (but cant for the life of me find the old posts) which is, for all games i tried, the image being very small and in the left hand corner of the screen (see first pic below).  i tested some of the modelines in arcadeOSD and they display ok there (see second pic below). so, not sure how to proceed now, perhaps i just did something silly in the mame.ini file? (eg. incorrent switchres options). would appreciate any help, many thanks!
NOTE: attached to this post is a game log (the problem occurs on all games i tried, horizontal and vertical).
also attached is directx dxdiag output data (wasnt sure to attach 32bit or 64bit so attached both).
MAME.INI:
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               1
sleep                     0
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
bios
cheat                     1
skip_gameinfo             0
uifont                    .
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
http                      0
http_port                 8080
http_path                 web
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   1
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   arcade_15
orientation               rotate_r
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         1
dotclock_min              0
sync_refresh_tolerance    10.0
frame_delay               1
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  1
multithreading            0
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                0
unevenstretch             1
prescale                  1
waitvsync                 0
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.03
pincushion                0.03
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.3,0.0,-0.3
converge_y                0.0,0.3,-0.3
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     1.570796325
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.225
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2.0
# INPUT DEVICE OPTIONS
dual_lightgun             0
Calamity
  • Moderator
  • Last login:August 29, 2026, 03:10:20 pm
  • Quote me with care
Re: Problem with the displayed image
« Reply #1 on: July 07, 2014, 06:09:32 pm »
This is probably the problem. CRT Emudriver for XP needs at least 17 different modes, otherwise dynamic modelines don't work (yes). Leaving the default resolutions in ReslList.txt will produce enough modes to keep the list above 17.
Steps to create a log:
adder
« Reply #2 on: July 07, 2014, 06:12:54 pm »
Quote from: Calamity
oops had no idea about that, ok i will give that a go and report back, cheers!
adder
« Reply #3 on: July 08, 2014, 11:23:46 am »
hey that seemed to work and i think things are ok now (the reason i sound unsure is, at first, after adding some additional modelines to get the list above 17, kungfu master did the 'squished in screen' thing again but only once and then seemed to be ok. also, it was strange as, for kung fu master (256x256 res) switchres was choosing (via the magic modelines) a resolution of 512x512 instead of 256x256.. rtype was also incorrectly choosing an interlace mode also. however, the problem seemed to go away, to be honest im not sure why. i didnt touch mame.ini,  some things i did (dont know if they affected anything) were deleting the files in the .cfg folder, also going into xp desktop, display properties and 'list all modes' under adapter information. and a few reboots. anyway now kungfu master is choosing 256x256 so thats good, rtype is ok also (not running interlace anymore).
   ... anyway now things seem to be ok and im loving groovymame :)
« Last Edit: July 08, 2014, 11:33:00 am by jadder »
