Author Topic: Check this out  (Read 7205 times)
  • Last login:May 30, 2026, 12:00:14 pm
Check this out
« on: June 22, 2014, 02:04:37 pm »
lilshawn
  • Last login:July 01, 2026, 04:44:09 pm
Re: Check this out
« Reply #1 on: June 22, 2014, 07:34:28 pm »
you should play "need for speed shift 2" or "dirt 3" with the oculus rift. BAM! right in your face!
Re: Check this out
« Reply #2 on: June 22, 2014, 10:29:16 pm »
The setup in the video is not mine, but I sure wish I had one like that.
Well Fed Games
  • Delicious!
Re: Check this out
« Reply #3 on: June 22, 2014, 10:40:20 pm »
Crazy to think that at his age I was still playing Pole Position on the Atari 5200.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: Check this out
« Reply #4 on: June 22, 2014, 11:52:24 pm »
When I finish the battletech pod (whenever that is) I was drumming around building a Race Car sim.  I've got three 23" monitors sitting around waiting to be used.  There is a whole site devoted to simpits with dudes building real Jet fighter sims with Metal lithography.  SUPER RAD stuff.  http://simhq.com/forum/ubbthreads.php/forums/81/1/Flight_Sim_Pit_Builders
lilshawn
Re: Check this out
« Reply #5 on: June 23, 2014, 10:09:21 am »
That hydraulic powered F1 race simulator you see pop up every so often on crackbook and other forums by "4star" is crazy as all hell. I'd love to build something like that. I mean, I could do it... if the software interface to the games was done and readily available. I know nothing of programming, but I can hack together a pump and hydraulic system to drive the works.
flight sim guys are crazy with their builds too. you think arcades are expensive? try pricing out some of those displays and controls at 200/400/800...1800+ a pop.  :o
Re: Check this out
« Reply #6 on: June 23, 2014, 10:49:41 am »
Do it Lilshwawn!!!
This would be real fun at parties, but youd need to put a cage around it to keep someone from falling into it.
I could see where something like this would cost a fortune. The mechanical parts alone would be very high.
  • Last login:July 02, 2026, 07:26:12 pm
Re: Check this out
« Reply #7 on: June 23, 2014, 12:24:22 pm »
There is a new technique floating around that I would like to try one day... wiper motor sims
I'm not sure if they could lift my fat butt, but not having to fool around with messy and costly hydraulics is worth the price of admission alone.
lilshawn
Re: Check this out
« Reply #8 on: June 23, 2014, 12:24:35 pm »
we have princess auto here...
i can get 1 1/2 inch bore cylinders with an 24 inch stroke for about 160 each.
some kind of drive motor....not sure what kind of spec you'd need for the quick reactions for the turning...but i'd imagine something not too crazy would be needed...you aren't turning 5000lbs with it. :dunno trial and error right??  :lol so figure another 200  then a pump. for 200 or 300.
you'd need some solenoid or motor controled valves to control the fluid which is probably the most expensive at about 300 a piece.
couple grand and some time could have yourself a decent start anyways.
the other option ive considered is an F-zero AX deluxe cabinet, but not many of those made it out of japan because they were expensive all hell.
Re: Check this out
« Reply #9 on: June 23, 2014, 02:21:30 pm »
Thanks for the video link Howard. Looks like windshield wiper motors are not just for turning monitors anymore. LOL
lilshawn, it would take a lot of time and money to do a project right, but the windshield wiper motors would be cheaper, however you wouldn't have the span (reach) that a hydraulic cylinder could have, so movement would be limited with the wiper motors.
lilshawn
Re: Check this out
« Reply #10 on: June 23, 2014, 02:49:24 pm »
i suppose a motor with a spindle on it  and some aircraft cable to attach to the "rig" (similar to an elevator) would probably get tangled up or maxed out and broken.  ???
you would still get your length of travel but using inexpensive servo motors.
*watches as this simple post by daold man turns into a build thread*  :P
looks like it pivots in the middle, the motors themselves are supplemented by gravity on the other side with the weight of the monitor/players legs offsetting the weight of the body and chair.
the motors would have to push very little if you get the balance right. (course it would be different for everyone who played.) perhaps  some balance weights to hang off the front (behind the monitor) to compensate for different people weights.
IE: made for 100lbs and you add 1/2 lb to the front for every pound you are over that.
« Last Edit: June 23, 2014, 02:57:59 pm by lilshawn »
Re: Check this out
« Reply #11 on: June 23, 2014, 04:37:41 pm »
Well if you are using a motor, the key is to have proper gearing.  The old Sega sims used motors with a screw drive and worked pretty well.  Likewise the wiper motors I linked to a geared surprisingly low.... people use them for Halloween animatronics all the time.  So yeah a motor would do, but not with a cable system.
As for basing one at 100 lbs..... that'd be an awful lot of 1/2 pound weights to hang.  I hover at around 220 these days.
lilshawn
Re: Check this out
« Reply #12 on: June 23, 2014, 05:07:51 pm »
i'm somewhere around 300....i'm looking at hydraulics  :laugh2:
Re: Check this out
« Reply #13 on: June 23, 2014, 05:56:04 pm »
Hmm... maybe we all need to build ark's exercise bike then and start a byoac fit club.  ;)
Re: Check this out
« Reply #14 on: June 23, 2014, 08:22:18 pm »
Maybe a mame cabinet powered off a bicycle pedal set up?
You stop pedaling, your game shuts off.
kahlid74
    • GamersAnon
Re: Check this out
« Reply #15 on: June 24, 2014, 10:12:29 am »
The hydraulic ones are awesome.  I was thinking of building one and then got side tracked with other things.  I kind of always wanted to work hydraulics into the Battletech pod so everytime the mech walks the pod shifts right/left and it shakes when being hit and it tilts you way back or forward if your mech gets knocked down/falls down.
Pipe dreams I suppose.
Re: Check this out
« Reply #16 on: June 24, 2014, 11:43:48 am »
It's the software that's more of a pain in the butt than anything else.
Basically you need full access to the cockpit/whatever's x y and z values in the game.  Then you need to write software on an avr that reads a series of pots on your rig to determine the current x/y/z and adjust accordingly.  That's not even taking into account speed of movement.
Even then you'll have issues.... like when the gameplay is over and the camera zooms out for a dramatic shot..... and your rig tries to mimic that.  Or other issues.
lilshawn
Re: Check this out
« Reply #17 on: June 24, 2014, 05:18:21 pm »
yes, i know nothing of this part...i wish i did though.
i do know lots of programs (source engine and unreal engine games do for sure anyways) have provisions in a "debug" sort of way where values are spit out during a game... tire friction values....steering wheel position,  aceleration/brake value...on and on. i guess it would be a matter of writing a TSR program of some sorts for the computer that dumps this info out a serial port or the like and have, like you said, an AVR microcontroller sort the data to control and feedback various whatevers.
it's kind of the same way the Oculus Rift works with the Vireio Perception drivers and standard 3D games (usually)... by having the data come out of the game engine, be intercepted by the Viereio software and have relevent data passed to the rift software (and relevant data pulled out/changed/etc.) and then passed along back to the game for final processing and display.
I basically know how it works, yet i know nothing of how it works enough to do something with it.  :-\
Re: Check this out
« Reply #18 on: June 24, 2014, 09:08:18 pm »
Recent discussion in the driving cab sub-forum:
http://forum.arcadecontrols.com/index.php/topic,139818.0.html
lilshawn
Re: Check this out
« Reply #19 on: June 25, 2014, 12:14:27 am »
man, i thought the sega "activator" was stupid, but jeez.
danny_galaga
  • Last login:July 01, 2026, 06:02:51 pm
    • dans cocktail lounge
Re: Check this out
« Reply #20 on: June 25, 2014, 03:31:23 am »
While it seems nice and all, that doesn't seem THAT special to me. Isn't that rig just a 'bought one'? Plus 3  monitors?
Re: Check this out
« Reply #21 on: June 25, 2014, 09:53:30 am »
Yeah, the kid is just sitting in an office chair at a desk.  Triple monitors are pretty common among sim racers, although I don't think I've seen the two end monitors mounted vertically before.
Re: Check this out
« Reply #22 on: June 25, 2014, 10:13:11 am »
I agree, it is probably all store bought, but still, it is inspiring, perhaps.
Generic Eric
Re: Check this out
« Reply #23 on: June 25, 2014, 03:21:38 pm »
What I don't get is all of the time/money spent for a higher degree of immersion, and the "driver" sits on a spinning chair?
I'm not saying he has to wear a fireproof suit and slide through a window to get in, but I know the seat in my car doesn't spin.
Re: Check this out
« Reply #24 on: June 25, 2014, 03:38:55 pm »
I don't see a bunch of time/money spent on a higher degree of immersion.
I see a clamp on PC wheel and triple monitors.  The monitors could serve other purposes.
My boss has triple monitors in his office and wouldn't know how to install a racing game.
Generic Eric
Re: Check this out
« Reply #25 on: June 25, 2014, 04:52:02 pm »
Spent the last 20 minutes or so looking for the link for a driving stand that looked like that (saw it yesterday) but couldn't find it again.
Re: Check this out
« Reply #26 on: June 25, 2014, 08:35:07 pm »
If you want triple monitors they have been having sales all spring/summer where you can get 3 24" monitors for around 300 bucks.
Of course the real challenge is getting a beastly enough pc and video card to actually be able to render a game on three monitors at full quality.
ark_ader
  • I glow in the dark.
Re: Check this out
« Reply #27 on: June 26, 2014, 02:16:38 am »
I have this setup with Eye Infinity.  And it works out pretty well.  I have another display via VGA2USB but it is too slow for gaming and I just use it for PDFs in portrait mode.  I'm hoping to mount these via a VESA bracket with a 40" on top.  I also have two projectors (hopefully another soon) for another eye infinity setup for flight sims and my Bike Interface.
I would prefer something like this:
