Author Topic: Here's an interesting "what if?"  (Read 2488 times)
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
« on: December 07, 2003, 03:14:09 pm »
What if you could adapt the vga output of an ArcadeVGA card to a set of component outputs and hook it up to any TV with a set of component inputs?  Since the ArcadeVGA outputs 15khz (which is what a standard-rez tv does) it seems possible.  Any thoughts?
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Here's an interesting "what if?"
« Reply #1 on: December 07, 2003, 03:30:08 pm »
*shrug*...  if you used the VGA breakout cable that seems highly likely ... but how common/cheap are TV's with true COMPONENT inputs laying around, as opposed to arcade monitors  (and don't forget mounting).
So yeah... if you have one of these handy seems like it would work swimmingly.  YMMV --> it's just a reasonable guess on my part.
good luck!
Rampy
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
« Reply #2 on: December 19, 2003, 02:13:54 am »
good luck!
Rampy
I don't know where the poster is located, but in Europa and many Asian countries RGB component input on TV has been pretty common for years.
Mostly the circuits on branded sets from Phillips, Panasonic and Sony can handle both PAL and NTSC input, so they are pretty much like any 15kHz arcade monitor.
« Reply #3 on: December 19, 2003, 04:50:09 am »
Yes TV's with Scart input usually have RGB inputs wired in, and can handle PAL or NTSC input.  The display using this and ArcadeVGA is superb - the same as an arcade monitor in fact :)
For once Europeans have something better than the Americans ;)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: December 19, 2003, 11:30:07 am »
Just to clarify something: Component Video is not the same thing at all as RGB. So RGB on European SCART can be used with the ArcadeVGA card, but component video as found on newer USA TVs is not the same at all as RGB. It's a more complex type of interface which uses a separate luminance/chrominance signal.
Andy
