Author Topic: Monitor Question  (Read 1547 times)
micro571
  • Last login:January 02, 2006, 03:46:30 pm
    • .:: JBProjects.net ::.
Monitor Question
« on: December 07, 2003, 02:19:17 am »
I've got a busted GO7 chasis and 2 GO7 tubes.  One is the tube that came with the chasis, the other is without a chasis.  If I fix the chasis, can I use either tube?
The original has some burn - so I'd prefer to use the other.  Are the two interchangeable?
Jon
-= Mame Arcade Machine * LED Screen * Potato Gun * LED Matrix * PC RC Car =-
www.JBProjects.net
Ken Layton
  • Guru
  • Technician
Re:Monitor Question
« Reply #1 on: December 07, 2003, 02:59:33 am »
Yes, you can swap the chassis between the two tubes you have. You may have to tweak the color trimpots on the neckboard to get the colors correct.
