Author Topic: Using a template for cab sides  (Read 3317 times)
johnndeanna
  • Last login:October 24, 2015, 10:12:47 pm
    • New cab for the back porch
« on: May 29, 2014, 08:41:12 am »
Hey all,
I have started on a new cab that I am having difficulty with and want you opinion. I have a crappy jigsaw and my 3/4" MDF first side panel looks like crap with blade wander and all. I am thinking that it would be far easier to make a template out of a piece of 1/4' ply and use my router to cut the panels from that. I am really not looking to buy a new jigsaw and I think it would be easier to make a ply template and get that shaped good. Thoughts?
John
Louis Tully
Re: Using a template for cab sides
« Reply #1 on: May 29, 2014, 08:50:52 am »
« Last Edit: February 12, 2015, 05:15:03 pm by Louis Tully »
DarakuTenshi
    • Card Fighters Project
« Reply #2 on: May 29, 2014, 08:51:41 am »
Well depending on the style of cab you are making you may be able to buy one. The arcade boneyard sells templates that you can trace with a router. Otherwise if you are using a jigsaw for your sides just take your time (use a sharp blade) and move slowly. Then trace that side with a router.
lamprey
« Reply #3 on: May 29, 2014, 11:54:51 am »
Not much too add other than templates and routers work great. I started cutting my wood last weekend and basically got one side done and then used that as a template for my router; Worked great.
I can't tell if it my lack skill or my jigsaw (or both) but I also have a heck of a time getting it to not wander. So, I tend to not use it very much. Not sure what is available in your area, but maybe it would be worth it to buy or rent a circular saw and just use the jig saw to complete any cuts/spots that the circular saw cannot complete..? I find that if I clamp a "fence" to what I'm cutting I can get very good results with a circular saw, for straight cuts of course. :)
Good luck with the build!
johnndeanna
« Reply #4 on: May 29, 2014, 02:08:23 pm »
Hey all,
John
100% go with a template/router combo. Spend time on your template and get it just right. Use your router to cut 2 identical sides and you'll be all set. I did this for my last build and it just doesn't get any easier. It's foolproof, IMO.
What was your plywood thickness? I am thinking 3/8".
Louis Tully
« Reply #5 on: May 29, 2014, 04:00:47 pm »
« Last Edit: February 12, 2015, 05:15:08 pm by Louis Tully »
johnndeanna
« Reply #6 on: May 30, 2014, 01:13:31 pm »
Thanks for the replies all. I'll be working on my template this weekend for sides and CP.
