Author Topic: Running retroarch in gameex  (Read 3326 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
« on: May 12, 2014, 06:41:47 pm »
Hi
Yesterday I was battling all day to run retroarch in gameex with no results. I use RetroArch-v1.0.0.2-64-bit version. Retroarch have frontend in itself via you can load different systems and games and most importantly have the best shader (download here and copy to shaders https://dl.dropboxusercontent.com/u/11217940/crt-interlaced-halation-tweak.rar ) which can emulate really well the crt rgb look of 240p games (IMO better than HLSL in mame), but the frontend itself is a lot worse than gameex. So it is really important for me to be able to use it in gameex. I want to be able to load retroarch already configured with specific system (it is called core in retroarch).  I tried to point to retroarch.exe and used commands that supposedly work with hyperspin like:
"retroarch -L libretro-git-snes9x-next-x86_64.dl game.rom" or "-f -D -L libretro-git-snes9x-next-x86_64.dll "%rom%""
When I make shortcut to retroarch exe and set this parameters in shortcut properties it work flawless, but when I try it in Gameex It just put me back to gameex or I get retroarch error window and then go back to gameex. Please help.
