Author Topic: hyperspin joystick issue  (Read 1710 times)
iamscottyb
  • Last login:July 26, 2018, 10:10:40 am
« on: May 12, 2014, 06:31:08 pm »
HS is running just fine with my keyboard, but when i plug in my custom control panel the joystick will not control the menus in HS. ive went to hyperhq and set my buttons under the joystick tab under controls still to no avail. im using a 2 player xin (not an ipac). any help would be appreciated.
SegaOutrun
  • Last login:March 28, 2019, 03:02:05 am
  • Brakes are overrated
Re: hyperspin joystick issue
« Reply #1 on: May 12, 2014, 07:49:52 pm »
did you click enable? there a lil box about the joystick controllers in hyperhq
iamscottyb
« Reply #2 on: May 12, 2014, 08:40:21 pm »
Yea I sure did
bleasby
  • Last login:May 03, 2023, 03:25:00 am
« Reply #3 on: May 14, 2014, 02:42:07 pm »
CVurrent HyperSpin has a bug with gamepad controls. Maybe it is that.
If it is the case, you will need to use a keymapper like joytokey or xpadder to use your gamepad with it.
