Author Topic: Sleepy's Arcade - Year Two - New Control Panel  (Read 3355 times)
Leapinleny
  • Last login:January 04, 2016, 03:26:12 pm
  • Working on Revision 2 of a year old Mame Cabinet
« on: May 10, 2014, 10:07:38 am »
Here is what I will call Rev 2 of Sleepy's Arcade, after close to a year of using the arcade regularly, I finally decided to put aside some time and redesign the control panel. Initially I was going to setup some sort of modular or two level control panel, but for this revision I abandoned that, and just made a slightly deeper single level "franken-panel" to support the games we have been playing.
The cab consists of a Pentium HT4 3.06 GHz CPU, 1 Gbyte RAM, ATI Radeon AGP 9250 Video Card, with a 40 GB and 80 GB HDDs running Windows XP, MAME 32 0.93
27" Zenith TV monitor with S-Video Input
Happ 3" Trackball (red translucent) to the PS-2 port with 3 button functionality
Happ 8 Way HD joystick with the TRON urethane from encryptor - works great
Ultimarc Mag-Stik Plus
Ultimarc SpinTrak
Ultimarc I-PAC4 (PS2)
Ultimarc PAC-Drive
Two Happ 8-Way Rotary Joysticks with 12 position encoder
Happ Buttons
Some lighted Multicade buttons
RED T-Molding
Here is where the arcade is at, I will be in the process of wiring up the buttons and joysticks today.
Leapinleny
Re: Sleepy's Arcade - Year Two - New Control Panel
« Reply #1 on: May 10, 2014, 10:10:39 am »
Here is a close up of the control panel without everything installed
Leapinleny
« Reply #2 on: May 10, 2014, 10:12:04 am »
Here is a close up of the control panel with the exception of connecting the joysticks from below, but in place
Leapinleny
« Reply #3 on: May 16, 2014, 07:19:20 pm »
Here is a close up of the finished panel. I had to move the exit button to where the 2nd pause button was. If I would have spent more time browsing the forums, I would have found placing the exit button above the trackball for games like golden tee and shuuz is bad idea.
Fortunately I had bought some blanks for the last panel.
Also have gotten all the side buttons and trackball lit up and running with the Ultimarc pacdrive, now it is just a matter of learning Mala and getting everything programmed.
Leapinleny
« Reply #4 on: May 16, 2014, 07:23:55 pm »
Here is the finished product for this year, maybe in another year I will redesign the panel again
