Author Topic: heres some pics of the custom tron handle insides I made (FYI)  (Read 2935 times)
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« on: December 05, 2003, 12:51:26 am »
well, I wanted the trigger plus 2 thumb buttons...and neon glow wire of course. The problem was making a hollow handle that worked with a happ joystick base.
So, after about 2 weekends of long days and many trials, I found a solution that works magnificently.
Pieces required:
12" of 1/8" galvanized nipple (hollow threaded on each end)
1/2" to 1/8" galvanized reducer coupling
1/2" PVC coupler
1/2" by 2" sprinkler riser
1. cut the nipple to length with a dremel.
2. sand down the outside ever so slightly so it will fit into a joystick base
3. use dremel to add a groove for the c-clip
4. screw everything together
5. sand the pvc coupler down to fit snugly inside the Tron handle
6. assembly your tron handle and run the wires through your new hollow joystick
the sides of the Tron handles screw into the riser for a tight fight. (use 1/2" or 5/8" screws)
The handles feel super tight - no wiggle at all.
Pics to follow
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
soslo
  • The Governator
Re:heres some pics of the custom tron handle insides I made (FYI)
« Reply #1 on: December 05, 2003, 12:52:14 am »
fits perfectly in the handle for a tight feel while playing
soslo
  • The Governator
« Reply #2 on: December 05, 2003, 12:53:02 am »
run the wires through. I could barely fit the 3 button wires, the ground, and the 2 neon wires.
soslo
  • The Governator
« Reply #3 on: December 05, 2003, 12:53:57 am »
here is a picture of the handles installed on their new home
soslo
  • The Governator
« Reply #4 on: December 05, 2003, 12:55:17 am »
and finally here is a poor picture of the handles glowing
Metimbo
  • Last login:June 15, 2010, 02:52:32 pm
  • A stretched mind will never be the same again.
    • Metimbo's Website
« Reply #5 on: December 05, 2003, 09:30:45 am »
Wow!  Those look great!  Good job!
~Tim
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #6 on: December 05, 2003, 10:54:39 am »
wow bit of engineering there, I'd never think of stuff like that.   Very cool.  Nice cammy, too :)
soslo
  • The Governator
« Reply #7 on: December 05, 2003, 11:14:38 am »
Thanks Frosty  ;)
I am very happy with the way the Cammy panel turned out with the trackball mount hidden and the ball right in the palm of her hand - you do very nice work!
1UP
  • Token Junkie
    • 1UPArcade
« Reply #8 on: December 06, 2003, 02:31:33 pm »
Why did you have to sand down the riser?  I used a 1/2" male-male (ABS?) riser that fit inside the handles with no problem.
What diameter was the nipple?  I find that 3/8" OD pipe fits into a Happ super joystick base perfectly.  How is the nipple attached to the reducer coupling?  How do you keep the stick from spinning around in the base?  Any problems with the coupling coming unscrewed?
My other job...
soslo
  • The Governator
« Reply #9 on: December 08, 2003, 03:53:59 pm »
1up -
I didn't actually sand down the 1/2" sprinkler riser - I just sanded the 1/2" PVC coupler between the riser and the galvanized reducer/coupler.
me too
I painted the whole thing black - otherwise you'd be able to pick out the dark grey riser and the white PVC coupler (I should have stated that above).
The nipple diameter was 3/8"  - but being galvanized it had some anti-rust coating that made it a *tad* larger, which wouldn't allow it to fit into the Super base without *a lot* of coercion. I ended up making about 6 handles/bases because I broke too many in the process with hammer/vice. Yeah - I get frustrated some times...
With a regular 1/2" PVC female/female threaded coupler
Friction :)  Actually, I was going to rig up a stop, but the wires were pretty tight and I taped everything well, so the handles resist turning fairly well. Of course, if someone really wanted to, they could spin it 4 or 5 times and pull something out...
No, that thing went on very tight (like plumbing should). It was actually very tough getting everything apart. You know how it is when you are engineering something for the first time - trial and error up the wazoo. I have full confidence in the handle strength...the felt quite stout after assembly was complete.
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: December 08, 2003, 04:06:06 pm »
Nice job, looks good!
