Author Topic: Anyone know something about hydraulics?  (Read 1515 times)
menace
« on: May 06, 2014, 01:27:47 pm »
So I picked up this hydraulic scissor lift (free--woohoo)  And the top O-ring had torn and the oil all leaked out.  Does anyone know how much goes back in or the proper way to fill it?
RandyT
  • Online Online
  • Last login:Today at 02:42:51 pm
    • GroovyGameGear.com
Re: Anyone know something about hydraulics?
« Reply #1 on: May 06, 2014, 01:56:07 pm »
I would only say to make sure the proper material was used on the replacement O-Ring.  There's a lot of pressure in there, and if it's not the correct type, any oil you do get back in, won't stay there :)
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #2 on: May 11, 2014, 01:23:43 am »
If you can't get the manual by googling the model number call the manufacturer and ask them to email/mail you you one.  Knowing how to fill it isn't as important as putting the right type of oil in it.  I'd also replace all the other o-rings while it's empty.
menace
« Reply #3 on: May 11, 2014, 07:35:05 am »
Yeah my google-foo must be weak--I couldn't find diddly on this thing--my guess is that it was made specifically for this jack and replacement parts would have to be cobbled together from other things.  I did manage to fill it and it will go up and down (although it goes down whether its being manually released or not  :-\)
In true BYOAC fashion I replaced the hydraulics with a 4 ton bottle jack for $9 and it works great now  ;D
Aside--I'm incredulous that I can buy a bottle jack for $9...there has to be more steel/labour etc. in it than $9...just goes to show the effect of overseas labour I guess..
