Author Topic: Nanao MS8-26A vertical hold issue  (Read 1825 times)
djrichoe
  • Last login:May 20, 2014, 01:17:24 pm
« on: May 01, 2014, 08:33:31 pm »
Hi Everyone I'm new at this and hopefully someone can help me with my issue. There were many threads on this and wanted to confirm its the exact same symptoms I'm  getting before I start ordering parts :)
What I have:
-The arcade monitor is a Nanao MS8-26A and has a Mitsubishi A63JHF81X tube.
- VGA Arcade 5000 ( driver was installed successfully no errors)
- JPAC ( all test lights are good green and orange) the only thing I have plugged is the video cables that go to the monitor and the pc/kb usb)
- JPAC Harness from jammaboard(connected blue , green ,red ,black and white with the old connector which connects to the monitor chassis (video input ) blue , green ,red ,white and blue with white stripes.
_ Windows XP 32 pro- Regular computer with AMD processor with 640 g HDD
No matter what I do I cannot get the image to display to stay STILL and its followed by lines when scrolling up..I've managed to keep it still with good image and color but after a few seconds its starts scrolling..the V hold is very sensitive and it also looks like the v position is non respondent and seems much loser then the other buttons in front. The monitor was first on 25khz (barely any image) I then switched it to 15 KHz and the image was great but not stable and not fully centered just keeps scrolling .
On other threads people have said change these (Replace C433 ( 10uf 50v ) and R433 ( 2.2K 1/4w ) , if still not deflection replace R436 ( 15K 1/4w ) and all should be good as its related to vertical and horizontal but I didn't want to start changing things especially when its not necessary :) , also I wouldn't even know as I don't have the schematics for this monitor.
Here is a video on the symptom itself:
https://www.youtube.com/watch?v=YZPOQhcM7yA&feature=youtu.be
Here is my Nanao MS8-26A board:
http://www.homearcade.org/BBBB/mon75.jpg
I really hope someone can help or guide me with this..thank you again for your time.
Rich
« Last Edit: May 02, 2014, 09:16:08 am by djrichoe »
djrichoe
Re: Nanao MS8-26A vertical hold issue
« Reply #1 on: May 02, 2014, 10:15:28 am »
sorry forgot to mention that the original game was working perfectly with no issues on the monitor.. it was DYNAMITE cop. adding another pic.
djrichoe
« Reply #2 on: May 02, 2014, 04:10:40 pm »
Issue resolve thanks to Joey - Japanese monitors , Sega , Namco etc have their own wiring code that messes up a lot of people !! , Red , Green and Blue are perfect , but Jap monitors White is Gnd , Blue with White Stripe is H Sync .Join Black from your Jamma to White on the chassis , and White from the Jamma to Blue with White Stripe. Voila its now pefect
