Author Topic: Anyway to remove flicker? ... (Solved)  (Read 1784 times)
Jollywest
  • Last login:Yesterday at 02:37:24 am
« on: April 23, 2014, 07:21:05 am »
Hi,
I'm trying to remove unwanted flicker from my setup, which is;
PC running Sega Model 2 Emulator connected to Sanwa 29e31s VGA arcade monitor.
I've tried to tackle this in the past, using powerstrip without any joy.
My question is, if I setup powerstrip to output at a lower frequency and then fit a CGA/EGA to VGA converter between PC and monitor would this remove the flicker?
EDIT
I managed to sort this by adjusting the 3D settings (anti-aliasing, anisotropic etc...) in my GPU settings.
« Last Edit: April 26, 2014, 02:00:53 am by Jollywest »
SailorSat
  • Last login:June 02, 2026, 10:13:38 am
    • For Amusement Only e.V.
Re: Anyway to remove flicker?... (CGA/EGA > VGA converter?)
« Reply #1 on: April 24, 2014, 07:45:40 am »
If I understand you correctly you drive the VGA monitor directly from the VGA card? There should be no interlace flicker then.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
Jollywest
« Reply #2 on: April 24, 2014, 11:50:00 am »
Not sure why I'm getting it then. It isn't there on the hyperspin frontend, it's only on the Sega Model 2 Emulator games.
I'm running the SM2 emu at 600 x 480 res, the same as the gpu card.
I've tried tinkering with the SM2 emu settings and resolutions without any luck.
