Author Topic: Atari 2600 Joystick to IPAC  (Read 3414 times)
BldnACab
  • Last login:May 11, 2010, 11:53:42 am
  • Doh!
« on: December 04, 2003, 02:09:21 pm »
Question:
Is it possible to connect an original Atari 2600 joystick to an Ultimarc I-PAC?
BldnACab
"Blue wizard has shot the food"
Jakobud
  • Last login:May 25, 2026, 02:04:14 am
Re:Atari 2600 Joystick to IPAC
« Reply #1 on: December 04, 2003, 02:30:33 pm »
I've never taken apart that joystick but I'm 99% sure it's totally doable and most likely very very easy.
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #2 on: December 04, 2003, 02:46:02 pm »
I've done it.
The 2600 joystick has one switch for each direction and one for a button, and they are all common ground.  It is basically the same as any joystick you'd encounter here except that it already has all the wiring done for you.
Somewhere on the web I found the pin-outs for these.  The plug on the end of the 2600 joystick cord mates to 9-pin sockets that look just like PC 9-pin serial ports.
Go get a Radio Shack 9-pin d-sub connector, run the wires to the I-PAC and you're good to go.
I posted about it here a long time ago.
Al
« Last Edit: December 04, 2003, 02:53:37 pm by MinerAl »
_Iz-
  • Last login:July 06, 2026, 10:35:57 pm
  • Time to coin up!
« Reply #3 on: December 04, 2003, 02:52:03 pm »
You can also connect an atari 2600 joystick to a parallel port very easily...
menace
« Reply #4 on: December 04, 2003, 02:54:16 pm »
I don't know why I didn't think of that   ???  That would so easy to then have a 4 player cab when the odd time came--just plug in the old boss joysticks and you're good to go!  thanks guys!
BldnACab
  • Doh!
« Reply #5 on: December 04, 2003, 02:57:29 pm »
Sounds great.
Thanks for the info, and the link.
BldnACab
MinerAl
  • duck
« Reply #6 on: December 04, 2003, 03:58:16 pm »
It's really nice on my one-player-to-a-side cocktail cab to let player 2 use the Atari Joystick for things like Joust and 1943.  If you can find an Atari 7800 joystick, it uses the same pinout but has extra pins for more buttons.
If you wanted to be extra cool, you could go for some of the arcade quality sticks Wico and others made for the 2600/7800 series.  There's a Wico brand 2600  ball top stick with a button at the top that might be really handy...
Chris
    • Chris's MAME Cabinet
« Reply #7 on: December 04, 2003, 04:33:54 pm »
An Atari 2600 has a common ground line with five signal lines.  I can't imagine why you couldn't hook ths to an IPac.
(9 PIN D-SUB MALE CONNECTOR)
Pin Description
1 - Up
2 -  Down
3 -  Left
4 -  Right
5 - Not connected
6 -  Button
7 - Not connected
8 -  Ground(-)
9 - Not connected
--Chris
BLACK KNIGHT
  • Last login:March 09, 2019, 08:02:19 pm
  • I'm a llama! A what?!
    • Mike's X-Arcade
« Reply #8 on: December 04, 2003, 04:46:15 pm »
Ok, I'm curious as to why you would want to use an Atari 2600 joystick instead of just getting a real one?  I mean I used to have an Atari 2600 and we went through some joysticks because they broke fairly easy.
Chris
« Reply #9 on: December 04, 2003, 05:11:11 pm »
Nostalgia.
--Chris
BldnACab
  • Doh!
« Reply #10 on: December 04, 2003, 05:54:43 pm »
Nostalgia.
Exactly. Even though video games/controllers have improved, I still find myself longing for the old days when a 2600 cartridge and a simple 2600 controller would keep me occupied for hours.
BldnACab
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #11 on: December 04, 2003, 06:12:30 pm »
  When you get the longing you should use a real Atari 2600.  :)  You can spend $75 on ebay and (through various sellers) get an atari 2600 and all the games you used to play.  I did that a couple years ago and still pull it out and play it once in a while.
For all the cash getting tossed around to build a cabinet, I'd think that more people would do this.
telengard
  • Last login:April 28, 2026, 11:37:11 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #12 on: December 04, 2003, 08:18:51 pm »
I've done this also.  I built a little box using an IPAC/OptiPAC, ps2 connectors
and dsub-9 and 25 connectors.  My hope is to interface all kinds of old controllers to it.  Right now all I've had time to do is the 2600 controllers.  But boy does it work great.  I played some Archon and One on One the other night for the first time w/ a second player and it worked perfectly!    :)
Combat and Space Invaders are so much more fun with these original controllers.  It's also very easy to use with emulators that do not support key remapping by using the programming utilities for the IPAC.
I started working on the Atari paddles but they use a POT and I wasn't sure how to hook that up to the Optipac.  So what I started doing instead was using a hacked mouse inside of the paddles.  Anyone have any tips on how I might be able to do this without so much custom work being done to the paddle?
If anyone is interested in pictures of this contraption I made I can get some to put up here.
« Last Edit: December 04, 2003, 08:20:00 pm by telengard »
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
Chris
« Reply #13 on: December 04, 2003, 09:49:12 pm »
You'll need to hook these up via a gamepad hack.
--Chris
Cameronj
  • Last login:August 03, 2012, 12:59:01 pm
  • I'm a Super llama!
« Reply #14 on: December 04, 2003, 11:07:13 pm »
Ohhh cool thanks guys for the info. Especially the pinout!  I have a good Wico bat joystick from my Atari ST that I used to play a ton of great games with. I can't wait to hook it into my IPAC for some Retro Atari fun. Sure my SlikStik has better arcade joysticks, but that wico bat stick was totally awesome!!!!!! I just bought another off of ebay too. yipee.
Cameron
paigeoliver
  • Awesome face!
« Reply #15 on: December 05, 2003, 12:31:05 am »
I have one of the Wico bat handled top fire ones, and the quality on it is first rate. Console sticks are usually junk, even console "arcade" sticks, but not this one, it is built better than anything you can buy today.
