Author Topic: cfg files  (Read 1640 times)
rooster
  • Newbie
  • Last login:December 06, 2003, 07:33:14 pm
cfg files
« on: December 04, 2003, 12:46:00 pm »
When I open cfg files to change button layouts, the cfg files are gibberish.  All I can see are x's, 0's etc, nothing makes sense.  I opened with Notepad, do I need to use a different program?
For example I wanted to remap the buttons for Mortal Kombat.  I went to Mame/cfg/ then the mk.cfg file.  Is this the correct way to change the buttons?
I am sure this is a stupid question, but any help is appreciated.
Tiger-Heli
    • Tiger-Heli
Re:cfg files
« Reply #1 on: December 04, 2003, 01:05:04 pm »
Stupider answer - Mame uses two types of .cfg files with the .cfg extension.  MAME/cfg saves dipswitch settings and such and can't be edited (as you found out).  (And actually the one's you want are .ini)
The ones you want are in mame/ctrlr/folder name (mine is "Myinputs")/gamename.ini (neogeo.ini), etc.
You also want to edit 2 lines in mame/mame.ini - (they might be commented out with a # ).  Under ### Windows path and directory options ###, add
ctrlr_directory         ctrlr
and under ### Input device options ###, add
ctrlr                   myinputs  (or whatever you named the folder)
Also see http://www.mameworld.net/easyemu/mamecontrolini.htm
or really any part of EasyEmu for more help.
_Iz-
  • Last login:Today at 12:14:59 am
  • Time to coin up!
Re:cfg files
« Reply #2 on: December 05, 2003, 05:40:39 pm »
Start a game, press tab, choose "input (this game)". Remap to your heart's content. This will change the cfg file...   note: don't pause the game when re-mapping controls!
« Last Edit: December 05, 2003, 05:42:26 pm by _Iz- »
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
Re:cfg files
« Reply #3 on: December 05, 2003, 10:34:58 pm »
yeah it'll change it...  for that game.  If you write the .ini files manually you can remap for a variety of games, based on circumstances, like "is NeoGeo" or "is a Mortal Kombat 3 clone" or "uses a spinner".
Course then you still have to deal with the occasional individual case, when you find out that Mame thinks Puzzle Bobble has a spinner in it and such, but you don't have to remap nearly as many.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
Re:cfg files
« Reply #4 on: December 06, 2003, 03:00:42 am »
when you make changes in MAME to the contol files (not dip switches) it appears to save those changes in the .cfg files..not INI
I'm having a hell of a time manually creating a MK.ini that works....
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
Tiger-Heli
    • Tiger-Heli
Re:cfg files
« Reply #5 on: December 06, 2003, 06:17:40 am »
Allroy
Ok, here's the problem - Changes to the DipSwitch settings and key assignments made through the User Interface (Tab Key - Inputs this game), are saved in the .cfg files and these override settings made in the .ini files.
Try this (although it's a pain), delete your .cfg files, get your .ini files working, then adjust your dip swithches through the UI but don't re-assign keys this way.
Eventually, I think MAME will add an .ini file structure for dip switches, and delete the .cfg files altogther, but no idea when this will occur.
