Author Topic: crt emudriver  (Read 7086 times)
Kenny301
  • Last login:May 03, 2014, 10:26:36 am
crt emudriver
« on: April 10, 2014, 09:14:51 pm »
Hello forum. I just joined here to get some questions answered about emulation on crt tv w/s-video. First off, my ati radeon 4350 (vistontek) came in today and put it in my optiplex 745 which I bought for the purpose of emulating older consoles on crt tv including mame. I heard that there are beta crt_emudrivers available for Win7 via messaging calamity. Since XP is no longer supported, I don't want to have to use xp to use these patched drivers and I'm wondering when the crt_emudrivers come out of beta?
Kenny301
Re: crt emudriver
« Reply #1 on: April 11, 2014, 11:49:46 pm »
somebody? anybody? I need answers!
69mustang
  • Last login:March 20, 2015, 12:31:40 am
Re: crt emudriver
« Reply #2 on: April 12, 2014, 05:20:52 am »
S-Video isn't going to output the correct resolutions and frequencies from groovymame. You will need a VGA to Scart cable and a Scart to YUV transcoder. This will output component video (not composite, better than s-video). The signal looks fantastic of SDTV CRT's.
Kenny301
Re: crt emudriver
« Reply #3 on: April 12, 2014, 11:25:15 am »
How would I do that on an ntsc crt tv with composite and s video?
69mustang
Re: crt emudriver
« Reply #4 on: April 12, 2014, 04:47:31 pm »
Kenny301
Re: crt emudriver
« Reply #5 on: April 12, 2014, 05:10:14 pm »
ok and how do i get the crt_emudriver for windows 7? I heard its in beta and was hoping to access the beta by messaging calamity.
Calamity
  • Moderator
  • Last login:June 16, 2026, 03:08:29 pm
  • Quote me with care
Re: crt emudriver
« Reply #6 on: April 12, 2014, 05:20:58 pm »
Hi Kenny301,
PM me and I can pass you the beta if you want.
However, you won't get any benefit from CRT Emudriver if you're using a s-video or composite connection. If your intention is to use s-video/composite then you don't need specific drivers at all. You use CRT Emudriver with a TV that has RGB or component inputs.
I don't know if the board linked by 69mustang actually allows custom refresh rates through composite. If that would be the case then it could be interesting.
BTW regarding the Visiontek cards, check this: http://forum.arcadecontrols.com/index.php/topic,138378.msg1431744.html#msg1431744
Steps to create a log:
Kenny301
Re: crt emudriver
« Reply #7 on: April 12, 2014, 05:23:12 pm »
what are the benefits? I want an as close to authentic picture as possible on s video until I can find a crt tv with component.
« Last Edit: April 12, 2014, 07:47:11 pm by Kenny301 »
machyavel
  • Last login:December 25, 2016, 10:23:52 am
Re: crt emudriver
« Reply #8 on: April 12, 2014, 07:48:15 pm »
Hello, the benefit of Calamity's driver is that it allows low resolutions through scart connection.
Kenny301
Re: crt emudriver
« Reply #9 on: April 12, 2014, 08:09:40 pm »
Then how would I get an as close to authentic picture through s video? Do I need the crt_emu drivers? What settings in groovymame should I use to get good results?
69mustang
Re: crt emudriver
« Reply #10 on: April 12, 2014, 08:49:26 pm »
You can't unless you use a converter like the one I linked. The money would be better spent on a CRT with component, check craigslist you can find them all day for $20-$50, then vga to scart cable and a scart to YUV/Component converter.  For Groovymame set the ini to arcade_15 and you should be fine. If you need more help on what settings do what, google it or read through the posts on this forum all of your questions so far have been answered in other posts.
Also here is link that shows that the converter I linked earlier has both composite video and s-video
http://www.ebay.com/itm/Weiya-CV-04-RGB-CGA-Arcade-Jamma-MAME-Cherry-Master-TV-composite-video-converter-/151257767204?pt=PCC_Video_TV_Cards&hash=item2337aa5d24
« Last Edit: April 12, 2014, 08:54:53 pm by 69mustang »
69mustang
Re: crt emudriver
« Reply #11 on: April 12, 2014, 09:00:02 pm »
I've used a similar converter (RGB to NTSC composite video and s-video) all lo-res progressive signals worked great, I never tried interlaced signals to see what would happen. Composite was not pretty to look at, but S-Video was sharp and colorful.
zebidia
  • Last login:February 04, 2016, 06:53:29 pm
Re: crt emudriver
« Reply #12 on: November 07, 2014, 01:19:31 am »
Hi 69mustang. I am going to try making the two-part cable you suggest for hooking up an old 24" Sony Trinitron (which I got for free) with component inputs to my (as yet to be delivered) ATI card. I want to try this approach before I take the easier way out and just go with a new g-sync LCD monitor (and accompanying gForce card).
As for the vga to scart, I can't find any North American distributors, but there are plenty to be had from ebay.uk, and I assume any of those will do the trick. Here's one example:
http://m.ebay.co.uk/itm/360953093876
And for the scart to yuv transcoder, I found this:
http://www.ebay.com/itm/Ananlog-Scart-RGBS-To-Component-RGB-YUV-Video-Format-Converter-/251203158378?pt=LH_DefaultDomain_0&hash=item3a7ce0016a
Do you think these two items will do the trick, assuming I'll be using CRT_Emudriver with ArcadeOS to control it all?
And the bigger question is, will the results be worth the effort/money, given that I don't want to blow big money on an arcade CRT... I would rather blow the money on an LCD instead.
Thanks for any opinion you can share.
69mustang
Re: crt emudriver
« Reply #13 on: November 15, 2014, 02:24:22 am »
Both those items should work just fine, you will need a separate cable for audio of course. The picture quality will be fantastic on an SD CRT TV like a Sony Wega, if you can find one.
« Last Edit: November 22, 2014, 03:13:15 am by 69mustang »
zebidia
Re: crt emudriver
« Reply #14 on: November 22, 2014, 01:48:30 am »
Thanks 69M. Bad news, though: I received the two items and the VGA-to-SCART cable is wired much differently than the wiring diagrams I have found elsewhere in this forum. Subsequently, it doesn't work on my Trinitron. All is not lost, though, as I now have a SCART connector to work with, and will hopefully get around to soldering up my own cable this weekend (I just need to pick up a male DB-15 solder-cup from somewhere... surprisingly hard to find locally). I will use the following as my guide:
69mustang
Re: crt emudriver
« Reply #15 on: November 22, 2014, 03:12:43 am »
I didn't bother with the diodes when I made my cable, I just tied H-Sync and V-Sync together. If you have the diodes I guess it would be safer.
