Author Topic: R-Type cabinet plans  (Read 1481 times)
xelanoimis
  • Last login:September 20, 2014, 04:04:01 pm
    • DizzyAGE
« on: March 18, 2014, 05:17:08 pm »
Hello,
Can anyone give some help with construction details for an R-Type mame cabinet?
I only saw the page from arcade museum and they do have some designs in the manual, but I still need some advice from people who built R-Type cabinets or who played the game on their similar machines.
Perhaps someone has the cabinet plans?
What buttons and joysticks to use? Would a SANWA JLF-TP-8YT be the best choice?
Another concern is about how much glare/reflections would the front glass do in a lit environment.
matsadona
Re: R-Type cabinet plans
« Reply #1 on: March 19, 2014, 09:09:25 pm »
Hm... looks to me that you could use the Donkey Kong plans (dimensions/measurements) and do some minor changes...
« Last Edit: March 19, 2014, 09:13:09 pm by matsadona »
xelanoimis
    • DizzyAGE
« Reply #2 on: March 23, 2014, 05:43:45 pm »
I could try with the image you posted, which if I'm not mistaken it's from the R-Type manual. Unfortunately it doesn't show the inclination of the screen.
About the joystick, I learned that the SANWA JLF-TP-8YT is best for fighting games and I might be better with Seimitsu SL-40 for shmups. SL-32 I heard it has a pop issue which might be annoying to me.
Anyone knows which joystick would be closer in feel to the original? Or just better?
Same question about buttons - I plan for Happ Standard Arcade (concave with cherry microswitch).
Any advice is appreciated.
matsadona
« Reply #3 on: March 25, 2014, 05:30:52 pm »
Well, the brackets (10 & 11 at the picture) should get you pretty close to the actual inclination even though the perspective makes it a little harder to figure out.
It is probably close to (or the same as) the other Nintendo machines I suppose, but there should be persons around here that could verify that.
