Author Topic: Bar Top Opinion needed  (Read 1403 times)
bclinton
  • Last login:November 12, 2014, 02:53:00 pm
« on: March 04, 2014, 01:46:22 pm »
Ok, work continues on my bar top. I am to the point now that I am working on the control panel. I entire CP area is about 20X9 inches. I am debating on setting it up for 1 or 2 players. I have the equipment for 2 but have started to wonder if I would be better off going for 1 player. I have a 2 inch trackball I also will be installing. 2 Player setup seems like it will be too crowded. Also, are there pre-made templates I can start with that has the joystick/ buttons layed out already to scale?
What do you guys think?
jdbailey1206
Re: Bar Top Opinion needed
« Reply #1 on: March 04, 2014, 02:02:14 pm »
BC - My first bartop was a two player but I only had two games that were co op and it's come to the point I am piecing it apart to make two separate arcades.  It seems like a good idea in the beginning to have a two player but once you see the limited space is kind of a ---smurfette--- and most games I played could be switched between the two players with one set of controls.  Oh well.  You can find most button layouts here.
« Last Edit: March 04, 2014, 02:04:06 pm by jdbailey1206 »
bclinton
« Reply #2 on: March 04, 2014, 02:20:21 pm »
Thanks! Great info. I think I will be going 1 player. I may also add a spinner. My full size is a tank stick pro with a spinner added. I cant remember the last time I used the second set of controls.
Thanks Again..
