Author Topic: testing transistors  (Read 1372 times)
lilshawn
  • Last login:January 15, 2026, 09:13:28 pm
testing transistors
« on: February 21, 2014, 02:00:31 pm »
I'm looking to "stress test" some TO-3 transistor pairs. 2N6284 and 2N6287's. these transistors are often counterfeited and sold as name brands due to their high price. I have a B&K 510 transistor checker, but often even with known blown transistors, they test as fine since a low voltage is used to test the simple switching function.
I'd like to build a test bed that i can insert a single or a pair and stress test them to...
1: determine if the transistors are good.
B: determine if they are rated for what they are supposed to be. high voltage, high amperage etc.
4: test "failed" transistors to see if they are in fact failed and not just another part of the circuit.
anybody know where i might start with this? i'm thinking a box with a power supply and some pushbuttons to apply voltage and amp meters to measure current draw and LED's to verify input,output.
spoot
  • Destroyer of electronics
Re: testing transistors
« Reply #1 on: February 21, 2014, 02:23:49 pm »
Not real familiar with this stuff..........but this German one might be a good basis to build off of?
http://www.mikrocontroller.net/articles/AVR-Transistortester
ed12
« Reply #2 on: February 21, 2014, 03:40:06 pm »
shawn
look up >peek<
look for dac77 or 75 ?
1 of them is a curve tracer
this is what u want
about $150.00 landed at your door
for any darlinton pair it is a must..hence the term :pair:
ed
