Author Topic: Cant get any buttons to work on one game in particular..Moonwalker..X Arcade  (Read 1915 times)
willybeamish
  • Last login:December 22, 2014, 01:59:10 pm
So in the mame set I have..there is 3 or 4 different version's of Moonwalker. I currently use a X arcade tank stick on Hyperspin. I have no issues with input on any other game. For some odd reason the Bootleg version of Moonwalker will respond to buttons however the screen does not display properly so its kinda useless. It wont work in either Mame itself or going threw Hyperspin. There is around 20 or so files in the Bootleg Zip vs the United states version Zip which only has 3 files in it. Ive tried re downloading United states Zip to see if maybe mine got corrupt but it didnt help. Ive tried re mapping keys and nothing seems to matter. Any ideas? Thanks guys and gals.
Currently rebuilding a PP cab and converting it to a mame cab..view the progress here http://forum.arcadecontrols.com/index.php/topic,122815.msg1305024.html#msg1305024
What version of Mame?  The Player start buttons were accidentally disabled in either 146 or 147 can't remember.
You might consider upgrading Mame.  Especially since The Gladiator is working now!
« Last Edit: February 17, 2014, 10:04:41 am by harveybirdman »
willybeamish
I cant recall the version on there ill have to check it when I get home from work..truthfully I really havent used my Cab in a longgg time. I just moved and put it in a more common area so its being used more. I wanna say my Mame set is one of those two thou might be 146. I need to do a refresher on how to update everything with mame lol
Do you have DD Crew?  If you do and it has the same or similar problems, then it's definitely the version of Mame you're running.
willybeamish
Im not sure ill have to check..can u give me a refresher on mame sets..pretty sure what I got last year was a No Intro set..I think that's what I want to stick with. I dont need to play every obscure game out there just the classics and some newish stuff if possible. Thing that sucks is that my computer is basically no frills dell with maxed out ram so I cant run any of the 3-D fighters.
willybeamish
Bump because im remembering stuff now I need to do lol
I remember im running Mame or MameUI with No Nag..I cant recall where I got it from to be honest. I know you can build one on your own but its a bit beyond me. Im seeing the newest mame set is 1.52 so I would need the 1.52 Mame emu as well correct? Does anyone have any links for a No Nag Mame 152?
thanks
willybeamish
My issue was fixed when I ran the newest version of the mame emulator. Im currently working on updating my Rom set to 152 today after. I dont have the HD space to get all the CHDs unfortunately thou.
