Author Topic: SOLVED --// Groovy Arcade Marquee Size and Spacing? Any Ideas?  (Read 6696 times)
jtslade
  • Last login:January 22, 2026, 03:19:42 pm
  • Keep it looking originallish!
« on: February 10, 2014, 08:50:08 am »
So what are my options to get the Marquee's to fill the screen. Do I need to resize them all in Photoshop or can I set some scaling options?
UPdate changing the size in Photoshop / Gimp (keeping the aspect ratio the same) does nothing, they stay the same size.
Just alot of empty black space...
« Last Edit: February 24, 2014, 09:31:22 am by jtslade »
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
Calamity
  • Moderator
  • Last login:Today at 04:35:40 am
  • Quote me with care
Re: Groovy Arcade Marquee Size and Spacing? Any Ideas?
« Reply #1 on: February 11, 2014, 04:19:16 pm »
Not sure if I understand. Do you want the marquees to fill the screen in Advmenu+? I think you can change the view by pressing the space bar. Maybe you need to treat them as normal snapshots... not sure.
Steps to create a log:
jtslade
« Reply #2 on: February 11, 2014, 05:11:50 pm »
Calamity,
thank you for the reply.
I want to change the scale so that there is not so much black space on the screen.
jtslade
« Reply #3 on: February 11, 2014, 05:19:04 pm »
Like this
Calamity
  • Moderator
« Reply #4 on: February 11, 2014, 05:47:29 pm »
I don't think you can do that without modifying the source code.
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #5 on: February 12, 2014, 11:07:56 am »
Calamity is correct. Use a different frontend.
jtslade
« Reply #6 on: February 13, 2014, 04:47:09 pm »
I found it. I set my Preview Expand to 1.85
I'll post some pics when I get home tonight.
set
preview_expand
5.1.8 preview_expand
Enlarges the screen area used by the vertical games on horizontal tile (and horizontal games in vertical tile).
preview_expand FACTOR
Options:
FACTOR    Expansion float factor from 1.0 to 3.0 (default 1.15)
Examples:
preview_expand 1.15
Calamity
  • Moderator
« Reply #7 on: February 14, 2014, 11:35:48 am »
Very good info, jtslade!! So good old Advmenu had an option for this after all. Don't forget to post a picture :)
jtslade
« Reply #8 on: February 14, 2014, 01:58:01 pm »
This is from my Virtual Groovy arcade that I use to test and config. Or what I use to waste time at work so that I can spend my time at home playing games.
When I get time tonight I'll upload a real pic from the Cocktail GA cab.
jtslade
« Reply #9 on: February 14, 2014, 02:09:03 pm »
Here are some of the Marquee's I am making for the menu. These are for ones that don't exist.
jtslade
« Reply #10 on: February 14, 2014, 02:19:51 pm »
Better Circus
« Last Edit: February 14, 2014, 04:54:48 pm by jtslade »
jtslade
« Reply #11 on: February 18, 2014, 01:06:34 pm »
Here is some pictures of the real world version cocktail cab.
Calamity
  • Moderator
« Reply #12 on: February 20, 2014, 10:08:05 am »
I love how this vertical layout looks now.
jtslade
Re: SOLVED --// Groovy Arcade Marquee Size and Spacing? Any Ideas?
« Reply #13 on: March 18, 2014, 05:07:46 pm »
More created Marquee's
Some are tough to find so I made them.
« Last Edit: March 18, 2014, 05:12:18 pm by jtslade »
jtslade
« Reply #14 on: March 18, 2014, 05:09:02 pm »
more
jtslade
« Reply #15 on: March 20, 2014, 03:59:07 pm »
more
jtslade
« Reply #16 on: May 02, 2014, 03:37:17 pm »
more
jtslade
« Reply #17 on: May 02, 2014, 03:38:11 pm »
more
