Author Topic: Which Controls to Get  (Read 2525 times)
Elias
  • Last login:March 20, 2008, 02:31:00 am
  • Shoryuken!
    • Shoryuken
« on: November 30, 2003, 11:53:31 pm »
I'm starting to close in on exactly what controls I want for my first custom stick, but I have some questions still. Any help will be greatly appreciated.
In terms of the characteristic differences of microswitch models, are there any in particular that come close to jumping from open to closed instantly? By instantly I mean the circuit is either completely closed or completely open--no partial connection. I guess physically, that would mean that once a certain amount of force is applied to the actuator (terminology?) on the switch, it quickly accelerates or "jumps" to close the circuit. Anyone know which microswitch would be particularly good at this?
In buttons, I'm looking for:
1. Horizontal microswitches.
2. Convex.
3. Button is low to the panel, i.e. it doesn't extend too high above the panel--more flat.
4. Button is fully depressed at the point that the microswitch is activated and there is little depression space.
5. Depresser with a large surface and thin rim (the part of the button that contains and surrounds the depresser). That is, a thin outer ring, and a big inner circle.
6. Good feedback--button springs back up fast.
The Sanwas seem to do the size right at least, but don't they all use vertical microswitches (bad)? Also, what size Sanwa button would you use for action buttons. Some of their buttons seem too big.
In joysticks, I'm looking for:
1. Microswitches.
2. Squared stick motion.
3. The stick should be fully extended at the point that the switch is activated.
The Happ Competitions are their best square motion stick (they beat their Ultimates I believe), but do they stop moving as soon as the microswitch is activated? I know Sanwas are good in the 3rd category (btw, are the Ultimarc J-Sticks completely interchangeable with Sanwa's sticks in terms of characteristics), but how does it (and any other sticks) perform in each category?
Tiger-Heli
    • Tiger-Heli
Re:Which Controls to Get
« Reply #1 on: December 01, 2003, 07:31:25 am »
Looks like you've done your homework, so I'm not sure how much I can add.
Digital microswitches are by definition either open or closed - there can be no partial connection.  This is true for any digital switch, including leaf microswitches.  You could theoretically get into a situation where the switch alternated between open and closed, (by moving the joystick within a certain narrow range), but that's about it, and not usually a problem.  For standard switches, the variables are - Activation Force - How hard you have to press the switch, how quickly it returns;  Free height - How high the button is above the panel when the switch is not pressed; and Total Travel - how far you can press the switch before it activates.
These might not be the correct technical terms, just good descriptive ones.
Convex buttons are going to pretty much leave you with either Happ Competitions or Sanwa's.
These three will be determined by the particular microswitch used in the button, and they are not always the same, even from the same manufacturer.  You could experiment with different switches to find the one you want.
Actually, I think it will come down to color for these - Sanwa's generally are available in Slime green, pink, and baby blues, Happ's are the more standard colors.
1. Microswitches.
Basically any modern switch except the Wico Leaf NOS or repro's.
Avoid Happ Supers.  Happ Comp's are good, as would probably be any of the restricted 4/8-way sticks - Omni-Stik (www.groovygamegear.com), J-Stick, T-Stick, or E-Stick - www.ultimarc.com
I don't understand this.  This would give you a large dead spot in the middle of the stick (no activation), and only activation when the stick is hard-over.  If you are really asking about short travel and high-precision, then I will again refer to the Omni-Stik (aka Suzo 500).  See OSCAR's draft review of them here: http://www.oscarcontrols.com/suzo500/suzo500.rtf and RandyT and OSCAR's comments on them in this thread:  http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=11929;start=0  It sounds like OSCAR got a stick with incorrect microswitches that behaved like you are asking about and hated it for reasons above.  Another reason to buy from www.groovygamegear.com is that I am pretty sure RandyT personally verifies the type of microswitches that each Omni-Stik comes with.
True.
No, and not a good idea, as above.
You might E-mail Andy Warne about this.  I know the T-Stick's have an added shim compared to the comparable Industrias Lorenzo stick, but not sure what, if anything, was changed on the J-Sticks, perhaps only the bat handle.
Good luck!!!
Elias
  • Shoryuken!
    • Shoryuken
Buying Sanwa Joysticks
« Reply #2 on: December 10, 2003, 12:15:12 am »
It turns out that the J-Sticks are slightly modified from the Sanwas. I'm sure they're still great, but I figure I should go for an original for my first Japanese stick to see what they are really like.  Besides, Ultimarc is sold out of the ball top J-Sticks (any idea on when you'll be restocking them Andy?).
So, I've come down to two different Sanwas from two different sites: Excellentcom (parts list here) and Cosmic Amusement (parts list here). What are the differences between these two sticks:
Sanwa from Cosmic Amusement
This one looks much like the J-Stick from Ultimarc. Does the pictured joystick use "leaf-like" microswitches like the J-Stick does?
Sanwas from Excellentcom
[big picture] ;)
This one seems to use microswitches without the "leaves" and seems to have an alternate shaft or cover.
Bear in mind that I'm looking for sticks geared towards Street Fighter. And the above sticks don't require some kind of special wiring do they, such as a power source (I read a hint of this in another thread)?
Also, Cosmic Amusement sells stick handles made by Asahi, and I was wondering if they might work on Sanwa shafts (I asked the seller but the question was left unanswered) since my friend wants a bat handle stick.
And, can anyone say anything about the stores themselves? What's their reputations? Do you think I will have trouble ordering from them as a consumer as opposed to a business--I'll be buying about $20 worth? Is it worth the shipping from Hong Kong?
Edit: Fixed the URLs.
« Last Edit: December 11, 2003, 01:29:28 am by Elias »
Elias
  • Shoryuken!
    • Shoryuken
« Reply #3 on: December 11, 2003, 02:54:00 pm »
Sorry for the bump, but I'm kind of desperate. :-[ Every thread deserves a second chance. Any help will be appreciated.
