Author Topic: Filling wood cut out with varnish ?  (Read 3559 times)
monkeychunkuk
« on: February 01, 2014, 08:28:40 am »
So this may have been mentioned  before but I can't find a thread about it?
On the bottom part of machine at the front I want to cut out a shape so I can see the PC and the blue lights to glow through,
Originally I had planned to cut the shape and just put a sheet of Perspex behind it.  But I remember seeing a table made from piece of tree and they has covered it lots of varnish and filled the knot holes with varnish (I presume) , so it made some sections see through.
Has anyone done this on one of their projects and can anyone think of the best product to use?
Many thanks
Steve
Unstupid
Re: Filling wood cut out with varnish ?
« Reply #1 on: February 01, 2014, 10:44:04 pm »
I'm thinking resin.... not varnish.
monkeychunkuk
« Reply #2 on: February 02, 2014, 02:37:09 pm »
Because?
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #3 on: February 03, 2014, 11:17:57 am »
Varnish won't ever build up to a substantial depth.
Resin will.
PixelPaul
  • Last login:February 22, 2026, 11:57:09 am
« Reply #4 on: February 03, 2014, 05:40:08 pm »
I think this is what you're looking for, MirrorCoat.
monkeychunkuk
« Reply #5 on: February 04, 2014, 10:32:02 am »
Yup the varnish didn't
Work after 4 hours it still like this
Ingesecition
  • Last login:October 23, 2014, 05:06:41 am
« Reply #6 on: February 05, 2014, 11:06:39 am »
Varnish uses solvents that dry off and cause shrinkage. Personally I'd angle the cuts and then cut Lexan to fit and bolt it down.
JDFan
« Reply #7 on: February 05, 2014, 11:30:40 am »
