Author Topic: Disabling OK-msg in mame?  (Read 6477 times)
delta
« on: March 21, 2002, 04:30:24 pm »
Is the any way to get rid of the "type OK to agrre"-message for each game in mame?
A little annoying to have that in the cab, specially when having to keyboard *inside* the cab ;)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: Disabling OK-msg in mame?
« Reply #1 on: March 21, 2002, 04:44:59 pm »
First, you can push left then right on player one joystick.
It is in the mame faq:)
Otherwise recompile mame.  It isn't hard to do.  First setup your computer and do a normail compile according to the instructions at mame.net.
Once you have a working EXE you can do changes and recompile.
To get rid of the OK:
Open mame.c in a text editor
Find the section
                       if (settingsloaded == 0)
                             /* if there is no saved config, it must be first time we run this game, */
                             /* so show the disclaimer. */
                             if (showcopyright(real_scrbitmap)) goto userquit;
                       if (showgamewarnings(real_scrbitmap) == 0)      /* show info about incorrect behaviour (wrong colors etc.) */
userquit:
Comment out those lines by puttin a // in front of each line.  So it will be like this:
//                        if (settingsloaded == 0)
//                              if (showcopyright(real_scrbitmap)) goto userquit;
//                        if (showgamewarnings(real_scrbitmap) == 0)      /* show info about incorrect behaviour (wrong colors etc.) */
                             init_user_interface();
                             /* disable cheat if no roms */
                             if (!gamedrv->rom) options.cheat = 0;
                             if (options.cheat) InitCheat();
                             if (Machine->drv->nvram_handler)
                                   void *f;
                                   f = osd_fopen(Machine->gamedrv->name,0,OSD_FILETYPE_NVRAM,0);
                                   (*Machine->drv->nvram_handler)(f,0);
                                   if (f) osd_fclose(f);
                             cpu_run();            /* run the emulation! */
                                   void *f;
                                   if ((f = osd_fopen(Machine->gamedrv->name,0,OSD_FILETYPE_NVRAM,1)) != 0)
                                         (*Machine->drv->nvram_handler)(f,1);
                                         osd_fclose(f);
                             if (options.cheat) StopCheat();
                             /* save input ports settings */
                             save_input_port_settings();
//userquit:
Save, then just recompile mame again.
Relker
« Reply #2 on: March 21, 2002, 06:58:29 pm »
Cool!  Thanks for the info.  I have a question if you don't mind.
Is there a way to compile Mame so that the display size stays the same? Or maybe limit the resolution?
There are some games that I play that are huge.  I can only see about a quarter of the screen.  This is for Dos only, the windows version works fine.
klutzo
  • Last login:May 27, 2005, 10:31:21 am
  • VIsit the Klutzoplex! www.klutzoplex. com
    • the klutzoplex
« Reply #3 on: March 21, 2002, 08:17:33 pm »
Arcade OS, FYI goes through all OK, and press to continue messages.
klutzo
game geek, ht geek, all round geek
feel free to visit the Klutzoplex!  www.Klutzoplex.com
SirPoonga
  • Puck'em Up
« Reply #4 on: March 21, 2002, 08:20:41 pm »
Cool!
jm
« Reply #5 on: March 22, 2002, 03:26:36 pm »
Is there anyway to disable ok in mame32?  thanks!
ArcadeFX
  • Last login:November 10, 2004, 11:16:56 pm
  • All the Dude ever wanted was his rug back!
    • ArcadeFX
« Reply #6 on: March 22, 2002, 07:16:04 pm »
Yea, recompile as mentioned above.
