Author Topic: Arcade OS with WinXp  (Read 4056 times)
mrmoomoo
  • Last login:November 30, 2003, 06:06:19 pm
« on: November 30, 2003, 02:57:28 pm »
ok
im trying to get arcade os to run... i run arcade os and it says license file missing... then i run pmwrap and arcade os and it gives me a bunch of errors and numbers can anyone help me!
SirPeale
  • Green Mountain Man
Re:Arcade OS with WinXp
« Reply #1 on: November 30, 2003, 04:29:11 pm »
The license file is license.txt, it's distributed with the distribution.
Also, I'm not 100% certain, but ArcadeOS isn't exactly made for XP.  It's more made for DOS.
mrmoomoo
« Reply #2 on: November 30, 2003, 05:15:51 pm »
well, im running it through the dos command prompt but it still isnt working
eightbit
  • My cab is never done...
« Reply #3 on: November 30, 2003, 06:04:53 pm »
Dos command prompt under XP is not DOS it will not work that way.
mrmoomoo
« Reply #4 on: November 30, 2003, 06:09:05 pm »
well i found Emetron...
it works with xp but i dont know how the features compare with arcade os better or worse
thanx
eightbit
« Reply #5 on: November 30, 2003, 06:18:27 pm »
If your not sure why your running arcadeOS you probably don't need to be. Its usually preferred by those that have to run dos and/or people running arcade monitors.
There are many other front ends available. Check the software forum for links. My favorite is Mamewah, http://mamewah.mameworld.net/
Newbies often use Mame32 because its easy to find and easy to setup.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #6 on: November 30, 2003, 06:38:06 pm »
Cocktail is a very similar frontend to ArcadeOS.  It can be rotated also.
EmuWizard is another frontend similar to ArcadeOS.  This one I use because I like it.
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #7 on: December 01, 2003, 06:09:05 pm »
You can get a pretty reasonable approximation of a DOS box under XP if you try.  I know of a few utilities that give your XP dos boxes emulated old-school Sound Blaster 16 support and the like.  There's lots of stuff like that on SourceForge.  (can't remember the URL - just google search for sourceforge and you'll go right there.)
If you're looking for a front end, try MameWah for a simple one or 3dArcade for that "wow" feeling.  (and look on the software forum.)
-EDIT-  and if you get your DOS progs running nicely under XP using anything on SourceForge, PM me cuz I've been toying with that as a sort of side project...  trying to get my old Ultima Underworld games to work nicely under XP dos boxes.   ;)
« Last Edit: December 01, 2003, 06:12:05 pm by grafixmonkey »
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
