October 05, 2026, 04:30:00 pm
My control panel layout has 6 LED buttons, is there a way to set LED to turn buttons that will b in use like if i play nes games only two shld come one...... or six for SF .
Quote from: Caparo8bit on January 27, 2014, 02:51:04 pmMy control panel layout has 6 LED buttons, is there a way to set LED to turn buttons that will b in use like if i play nes games only two shld come one...... or six for SF .Research "LED Blinky".
Quote from: yotsuya on January 27, 2014, 02:52:25 pmQuote from: Caparo8bit on January 27, 2014, 02:51:04 pmMy control panel layout has 6 LED buttons, is there a way to set LED to turn buttons that will b in use like if i play nes games only two shld come one...... or six for SF .Research "LED Blinky". my buttons already come with LED so if i want to do this do i need to add resistors to all?? planing to use LEDwiz with LEDblinky
And, whoa, what happened to that button? Did you pull it apart?But yeah, you can see the resistor. You should be fine. Just following the LED Wiz wiring diagram.
The smaller sanwa's (used mainly for start-buttons) come as screw-in buttons as well, fyi.
In case you're interested, here's a quick comparison shot of a 24mm screw in Sanwa (orange) compared to a 30mm snap in.
This ---smurfing--- graphic creeps me out, bro.
What's the issue, compa?
