Author Topic: sanding and painting cabinet and control panel have questions?  (Read 2722 times)
drummer4261900
  • Last login:April 16, 2014, 03:03:32 pm
« on: January 26, 2014, 11:11:55 am »
What grit sand paper do I need to use?  What kind of paint and primer should I use I was hoping to go buy some spray paint from Walmart?  I want to paint everything black.  I am going to cut a spot for my X Arcade 2 Player Joy Stick on Tuesday when it comes.  So there wont be any more holes.
Thanks in advance for any help!
jLid
  • Last login:May 14, 2015, 10:52:34 pm
Re: sanding and painting cabinet and control panel have questions?
« Reply #1 on: January 26, 2014, 02:23:17 pm »
I'm not sunow the professionals on here do it, but I start with 60 grit for a rough sand, than 120 grit to smooth it all out. Never built my own before, so I used 60 to get the paint off. After 120 grit I fill in any imperfections with wood filler and sand a second time with 120, than off to prime.
When priming I use 220 grit and do two coats, sanding between both.
But I'm a newby at this stuff
« Reply #2 on: January 26, 2014, 03:47:42 pm »
if available, try powder coating
drummer4261900
« Reply #3 on: January 26, 2014, 04:41:19 pm »
thanks for all the help any suggestions on paint or primer?
