Author Topic: Rebuild a Bally Midway Tri-Sports Arcade into a 60 in 1 Multicade Questions  (Read 6021 times)
robfg67
  • Last login:March 18, 2014, 07:18:11 pm
I just picked up a 1989 Bally Midway Tri-Sports Arcade Game in working condition that I want to rebuild as a 60 in 1 Multicade. I am a newbie and have a few questions:
1. Can someone suggest a good DIY thread that will help me change out the game board and controls? The cabinet is in good enough shape and the 19" Monitor is in good shape so I don't need to rebuild/replace those.
2. I would like to rebadge it in original Pac-Man (yellow). Would the replacement side decals work with this cabinet?
Thanks in advance and any tips would be appreciated.
Rob
robfg67
Can anyone suggest a supplier for the parts? Boards, Controls, etc...
  • Last login:Yesterday at 09:05:24 pm
One reason that people aren't posting suppliers for X-in-1 boards is that they run unlicensed ROMs using an outdated/illegal distribution of MAME.
Posting links to x-in-1 boards violates Rule 5.   :police:
Another thing to consider is that the board and wiring harness in your cab are not JAMMA, which limits the number of plug-and-play options you have available.
If you're looking to put a JAMMA x-in-1 board in your current cab, there are two basic approaches:
1.) Carefully remove the old board/wiring harness (don't cut the harness if you can avoid doing so) and make a replacement control panel.
2.) Space permitting, leave the current board/harness as is, unplug the control panel and make a replacement for it.  Mount the JAMMA board and harness where you can.
Either way, try to make any changes easy to undo in case you decide to reverse the conversion later.
robfg67
PL1:
Thanks for the info...I thought post 1985ish arcade games had JAMMA boards & wiring, so thanks for the clarification.
PBJ:
Thanks for the sarcasim. I have spent literally hours searching for a very simple instruction set (on this forum, Youtube, and old fashion Google search) for what I want to do and have found nothing close-although 1001 ways to build a cabinet from scratch. I wasn't asking for someone to write up a custom DIY, just to point me in the right direction.
paigeoliver
  • Awesome face!
Wow, I know a literally know another guy named Rob who rebuilt a working Tri-Sports into a 60 in 1, and last I checked he still hadn't been able to sell the thing.
Putting Pac-Man stickers on the side of that would be the equivalent of setting a couple hundred dollars on fire, except that it would look worse.
Any reason why you feel the need to rip up a working semi-rare dedicated game when there are so many incomplete conversion cabinets out there?
Actually, I was just assuming you had a dedicated one, since the few I have seen have been dedicated, they made them in kits too. Post a picture of what you have.
Rob
jtslade
  • Last login:August 17, 2026, 10:09:51 pm
  • Keep it looking originallish!
Sell the tri sports on klov then take the money and get a Jamma no name cab with big monitor.. Sell the Jamma pcb if it has one..
Then get a 60 in one, but remember that many people here say that the game emulation drives them nuts and some then go either arcade sd, pc Mame or groovy arcade or another variant..
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
jtslade
Post pics.. Was this a pacman conversion?
paigeoliver
  • Awesome face!
Tri Sports is not Jamma.
  • Last login:October 06, 2026, 11:37:34 pm
Sweet.  We're back to deleting posts.
What does it matter if the mods do it or you delete your own?  :dunno
robfg67
Wow, thanks for all the posts!
First of all, here is a Photobucket link to pictures of the game:
http://s244.photobucket.com/user/robfg67/slideshow/Bally%20Midway%20Tr-Sports
Can someone tell me if this is a dedicated Tri-Sports machine?
:banghead:   Why are you acting surprised?   :banghead:
About the same time that your post mentioning an x-in-1 vendor by name was deleted, Saint sent this multiboard B/S/T post to post hell.
paigeoliver
  • Awesome face!
Ok, not dedicated, that is a Time Pilot cabinet. Convert away.
Tri Sports is not Jamma although some of them I have seen have a jamma adapter board installed. The 60 in 1 isn't going to be a direct drop in though, you will still have to do some rewiring because of the trackball.
robfg67
Thanks, the big question is why someone would want to convert to Tri-Sports...must have led a sheltered childhood!
jtslade
Wood grain laminate looks like its In Great shape...
Arcade SD use the trackball
paigeoliver
  • Awesome face!
Tri-Sports is a pretty decent game. It is a pretty direct upgrade over any of the single sport trackball titles you could get back then.
